F5 power amplifier
F5 power amplifier
Old 12th January 2012, 06:26 PM   #11601
Rixsta is offline Rixsta  United Kingdom
F5 power amplifier
Default using 35v Transformer?
I have a Centre tapped Toroidal here, two sets of 35V / 4,3A = 2 x 208Watt
so i was wondering if its possible i can use this for the F5 if i use half the winding then i could get two sets of 17.5v ? which seems perfect to me, i dont know of any other way to get ~18v i need from this transformer.
Cheers Riki
Old 12th January 2012, 06:31 PM   #11602
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 12th January 2012, 06:51 PM   #11603
F5 power amplifier
Hi sorry im not that knowledgeable in electronics, basicly is it possible to use only one half of transformer for example..
just use 15volts rather than the full 30, its basicly a 35v transformer i have so i need half that for the F5 psu i think, and i also do not know the drawbacks to doing this if it works, im probably posting in the wrong place for newbie questions lol
I previously built the lovely sounding Zen V4 amp by Mr Pass, but just feel a bit uncomftable with the Psu side of things!
Old 12th January 2012, 06:59 PM   #11604
Zen Mod's Avatar
F5 power amplifier
1. what is declared voltage of primary ( 2x115Vac ? ) ?
2. what is declared voltage of secondary ( 2 x 35Vac ? ) ?
3. what is declared VA for normal connection ( core VA ) ?
Old 12th January 2012, 07:22 PM   #11605
F5 power amplifier
ive just answered my own question
2 secondarys
PRI = 230v ac Brown-Blue
SEC 35v ac / 4.3A
SEC 35v ac / 4.3A
two secondarys with no centre-tap, i got it wrong basicly i cant use this with the F5 as the voltage is way to high! hah u learn!
Old 12th January 2012, 07:38 PM   #11606
6L6 is offline 6L6  United States
6L6's Avatar
F5 power amplifier
Rixsta - to verify, it has a single primary?
Old 12th January 2012, 07:46 PM   #11607
Variac is offline Variac  Costa Rica
diyAudio Editor
Variac's Avatar
F5 power amplifier
Solution is easy - move to USA or other country with 115v mains, and the transformer will be perfect voltage. A bit small VA though
2 secondarys
SEC 35v ac / 4.3A
SEC 35v ac / 4.3A
"The geek shall inherit the earth"
2017 Burning Amp is November 12 in S.F. Thread here on diyAudio:
http://www.diyaudio.com/forums/clubs...francisco.html
Old 12th January 2012, 07:59 PM   #11608
Zen Mod's Avatar
F5 power amplifier
either that , or to use looooong extension cord
Old 12th January 2012, 08:04 PM   #11609
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 power amplifier
I'm done taking photos and such and then I'm off to the coast to write
the text. This and the F6 will be done before the end of the month.
There are several versions of the F5 TURBO.
Lots of room to play.
Old 12th January 2012, 08:07 PM   #11610
EUVL is offline EUVL  Europe
The problem can easily be solved by splitting the single rail with too high voltage into splitted rails using a simple discrete virtual ground circuit, e.g. :
Virtual Ground Circuits
I have used the Sijosae circuit in the above link successfully in my very first 4-FET Aleph-X. You just need to use high power BJTs instead of those small signal devices in the schematics. In my (antique) version, the bias was set at 200mA.
The circuit based on a single BUF634 is also a good one and easy to build.
Patrick
xen-audio.com
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
