Old 26th November 2011, 09:48 PM   #11251
tinitus is offline tinitus  Europe
just to make it clear, I do not know this stuff
but from what I have been told, I doubt very much they will be that accurate
have you tried to measure them again, on a different day ?
on the good side, you might have several nice pairs, and not just one
btw, anyone ever tried to blow hot air on them, with a fan or something, to see if they follow each other, and change in unity ?
Old 26th November 2011, 09:58 PM   #11252
alazira is offline alazira  United States
alazira's Avatar
Hi Tinitus,
Well, I found better accuracy with 100 ohm (then 1V=10mA) and most digital multimeters will give down to hundredths reading. I suppose one could warm the jFets to a specific temp for better matching. It should be good enough for sorting or approximate matching, if not precise Idss.
Old 26th November 2011, 10:02 PM   #11253
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
normal jig with 9V voltage source , DMM as current meter
one , two , three , five
read
next
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 26th November 2011, 10:04 PM   #11254
well, you still have a lot other components in the curcuit, which probably cause much greater variation
hence I doubt such great accuracy matters that much
but ofcourse it doesnt hurt to try
hell, I need to get on with it and try it myself, and hopefully soon
Old 26th November 2011, 10:19 PM   #11255
read
next
first I thought, sloppy zenmod
but then this way you might actually take into account the temperature coeffciency, rise time factor, or whatever its called
dont say you didnt think of that
Old 26th November 2011, 10:23 PM   #11256
Zen Mod's Avatar
one number for each leg , then some
who needs logic all the time ?
Old 27th November 2011, 04:35 AM   #11257
EUVL is offline EUVL  Europe
The methods described in post #11251 and #11254 are both very accurate.
The greatest contributors to inaccuracy are (in random order) :
1) Multimeter accuracy and resolution
2) Thermal drift of the JFET
3) Drift of your multimeter
To observe (2), put a low Idss JFET (say 7mA) on as described in #11251 for 5 minutes, and observe how the reading goes up and down, then breath on it, or just move your body away from the bench. If you have a 4~5 digit multimeter, you can see these effects quite clearly.
Single point methods only give you match at one point. See :
xen-audio
xen-audio
Patrick
xen-audio.com
Old 27th November 2011, 05:36 AM   #11258
erpiii is offline erpiii  United States
Originally Posted by AndrewT View Post
As a first, test the jFETs for Idss.
Using the method 6L6 supplied, I get 9.15 volts (new 9V batt voltage)... which I'm guessing means they are bad and I need new ones.
erpiii
Old 27th November 2011, 07:03 AM   #11259
If you are using the method described in post #11251, then I do not see a 1k resistor, across which the multimeter should be connected to measure voltage.
Patrick
xen-audio.com
Old 27th November 2011, 08:16 AM   #11260
Have anybody looked into using a soundcard to make a simple curve tracer for this small signal stuff?
LR out could be used to sweep Vg and Vd and LR in to monitor currents. (of course with proper signal conditioning in between)
Even tough most soundcards are AC coupled the measurement could be done around a "known" manually set bias point.
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Dennis Hui, Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.18290 seconds (57.53% PHP - 42.47% MySQL) with 11 queries
