F5 power amplifier
F5 power amplifier
Old 22nd November 2011, 08:59 PM   #11201
GOR3 is offline GOR3  United States
Old 22nd November 2011, 09:20 PM   #11202
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
ClassA fish. Though, are the fins large enough?
Old 22nd November 2011, 09:22 PM   #11203
It's a turbot, operating in Class Sea. Water cooled.
Old 22nd November 2011, 09:46 PM   #11204
bsabel is offline bsabel  United States
HAHAHAHAHAHAHA!!!! Now that's funny!
Old 22nd November 2011, 09:50 PM   #11205
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
It sure doesn't at half an hour's drive from my place.
Seafarm - Razor Clams
(ahh, the downsides of being able to have fresh turbot 7/7. Frozen turbot taste like crab from buttock)
Old 23rd November 2011, 02:39 AM   #11206
CanAm Man is offline CanAm Man  United States
Originally Posted by Nelson Pass View Post
The F5 continues to be more popular than I expected. As a reward to the
faithful, I have completed the F5 Turbo.
The pc boards are on order, and when they arrive I will present it complete.
ps - you can modify existing F5's to make one.
A turbo? Wow--I'm ready to order intercoolers and larger fuel injectors today!
Old 23rd November 2011, 03:24 AM   #11207
6L6 is offline 6L6  United States
6L6's Avatar
F5 power amplifier
As long as we are making the automotive analogy, you might want a bigger cooling system...
Old 23rd November 2011, 04:59 AM   #11208
EUVL is offline EUVL  Europe
Turbo means more power without adding engine capacity.
So more power without adding output devices and increasing power supply ?
Patrick
xen-audio.com
Old 23rd November 2011, 09:00 AM   #11209
R.I.P.
Turbo and similar supercharging, usually means more air and fuel input resulting in more torque.
regards Andrew T.
Old 23rd November 2011, 10:24 AM   #11210
triode_al is offline triode_al  Netherlands
triode_al's Avatar
In an engine, the increased output pressure feeds back into more input pressure.
I see turbo in our domain as a kind of feed-forward, or positive feedback. Think bootstrap or Quad 405. Also some tube amplifiers like MacIntosh C22 had a positive feedback loop between anodes and cathodes. An interesting turbo configuration has been mentioned for a tube output, where a cathode resistor connects to the gate of a high-voltage FET device - as the 300B ran into e.g. 200 mA, the increased cathode voltage opens the FET - implying a partially decoupled cathode of course.
What I could expect here is some merge of F5 and BA-3/BA#2 typology. For instance, some extra output devices that only kick in after some threshold in current is reached.
Just thinking - For fun: instead of having the limiter output from Q5/Q6 LIMIT the drive voltage to the output FETs Q3/Q4, have that DRIVE a BA#2 push-pull output stage. So the LIMITER becomes a BOOSTER.
But we wouldn't have to stop here:
In such a topology, it might be possible to insert a small resistance between the two output stages I think, it's value being trial & error.
What I am thinking about: A variable feedback differentiation was also once used in a Kaneda amplifier, where a potmeter of 100 ohms was used to change the amount of coupling between the output of the driver stage & the push-pull output. It has impact on the damping. (A positive influence, for many loudspeakers, less is more - less damping more enjoyable). In such a config the closed loop amplification stays the same, the output impedance differs.
And hence: you can dial in more "BA-3/BA#2 style sound" versus "F5" sound.
albert
Background on Kaneda design: 'Un amplificateur classe A 50W+50W, 1re partie: conception générale, P. Johannet & W. Walther, L'Audiophile, No. 43, 1988
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
