F5 power amplifier
F5 power amplifier
Old 28th October 2011, 06:50 PM   #11111
bobodioulasso is offline bobodioulasso  Europe
bobodioulasso's Avatar
The answer seems to be into the question.
"The stock F5 circuit is a little shiny. Paralleling up outputs might help your
perception of the amplifier."
Old 28th October 2011, 08:12 PM   #11112
alazira is offline alazira  United States
alazira's Avatar
vtr,
Increase feedback resistors R9-12 to 200R and source resistors R3/R4 to 20R (R1 schematic). It will produce a warmer sound as well as increase output volume
Old 28th October 2011, 10:00 PM   #11113
jameshillj is offline jameshillj  Australia
Change resistors to carbon will alter the balance of the sound quite a lot (gate stoppers, main I/V, f/back, power fet sources) plus using soft recovery diodes, Elna power caps, and increasing the 'R' in the C-R-C power supply (or use a choke), multi-stranded wiring, etc will all contribute to a "softer" sound - there's no end to the combinations.
Also, early on in this thread, "jackinj" did a sim design with input resistors and caps, and you can also use "juma" BF862 for an input gain stage that can be setup for a "softer" sound, or you could even build an input valve gain stage like in the Moskido ......
Old 29th October 2011, 08:23 AM   #11114
vtr is offline vtr  Switzerland
Default thanks this sounds good
as i would like to keep my single pair output irfs ill try to reduce feedback-any stabilty problems with half the feedback?
i use the original schematic and will take out one 100r feedback resitor
and i use already a choke input supply, and i keep my solid cables i avoid stranded wire whereever possible as i trust Allen wright principles
Originally Posted by alazira View Post
vtr,
Old 29th October 2011, 03:19 PM   #11115
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
F5 power amplifier
The F5 is right on the edge of what of how much feedback you can use
without compensation capacitors. Reducing the feedback on it won't
hurt it at all.
Old 29th October 2011, 04:01 PM   #11116
formula 22 is offline formula 22  El Salvador
formula 22's Avatar
Hi people!
I'd say that is definitely the ultimate schematics of the audio amplifier F5.
Place the schematic here and move on.
On which side of this post I can see a picture made ​​amplifiers F5?
thanks and cheers
Old 29th October 2011, 04:48 PM   #11117
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Oye hombre, no tiene ninguna idea qu t dices, no ?
Old 30th October 2011, 05:59 AM   #11118
formula 22's Avatar
Hi
I'd write in English to understand the other id.
Old 30th October 2011, 08:19 AM   #11119
triode_al is offline triode_al  Netherlands
triode_al's Avatar
Originally Posted by formula 22 View Post
Hi
Sorry, I don't understand what you [2] are talking about
LOL
SPU --> tube MC/RIAA;
Pass buffer -->300B SE + DN2540 CCS/Buffer; --> 165GMF in TQWT; working on a HYPEXed sub.
Old 30th October 2011, 10:43 AM   #11120
h_a is offline h_a  Europe
h_a's Avatar
Don't forget that your amp's gain will increase accordingly. Hannes
High Octane phono preamp Wiki
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
