F5 power amplifier
F5 power amplifier
Old 23rd October 2011, 08:11 AM   #11081
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
F5 power amplifier
Thanks for the comments guys
NS: Tried swapping inputs already and that makes no difference, the hum stays in the same channel. I have a (dual-channel) scope, so I will do some poking around with that
Andrew: Curious as to why you recommend this, is it because of the load on the PSU (the amp is dual-mono, so presumably no difference) or because of grounding?
/U.
Old 23rd October 2011, 10:41 AM   #11082
Originally Posted by Nisbeth View Post
.............. Curious ............... or because of grounding?
different routes for the return currents between the two channels. That's why I find it much easier to get quiet monoblocks. They cannot have different routes between channels when there is only one channel.
regards Andrew T.
Old 23rd October 2011, 02:19 PM   #11083
mfrimu is offline mfrimu
Would using two transformers be 'monoblock' enough ? I still have not ordered the transformer, would not be that hard to get 2x200VA instead of one 400VA.
Old 23rd October 2011, 02:29 PM   #11084
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
F5 power amplifier
Originally Posted by mfrimu View Post
---------- would not be that hard to get 2x200VA instead of one 400VA.
or 2x 300VA
or 2x400VA, if you should choose to make it balanced one day
Old 23rd October 2011, 02:58 PM   #11085
No,
Monoblock means one channel. There cannot be shared common routes for any flow nor return currents in a pair of monoblocks.
regards Andrew T.
Old 23rd October 2011, 03:17 PM   #11086
Ok, but putting 2 monoblocks into one chasis ? What's the difference?
Old 23rd October 2011, 03:22 PM   #11087
They will share some wiring. They are no longer monoblocks.
If we were sufficiently competent to build safe Double Insulated equipment then a dual mono could perform electrically as two separated monoblocks. But we can't, so we are stuck with stereo, dual mono, or a pair of monoblocks. They all perform differently electrically.
regards Andrew T.
Old 23rd October 2011, 03:24 PM   #11088
6L6 is offline 6L6  United States
6L6's Avatar
F5 power amplifier
Nelson Pass, in his article about power supplies, says that separate transformers and capacitor banks gives you most of the benefit of monoblocks.
http://passdiy.com/pdf/powersupply.pdf
Look under 'mono operation'
Old 23rd October 2011, 11:50 PM   #11089
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
What if I put two monoblocks inside one big enclosure? They'll still be monoblocks. What if I start taking out pieces from each monoblock original enclosure, at what point is the two monoblocks situation turned out to be dual mono?
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 23rd October 2011, 11:59 PM   #11090
F5 power amplifier
dual mono is 'basicly' two mono blocks in one box
means each channel have each their own complete power supply
but they share the same ground, through chassis
and ground connects to signal ground(neg), one speaker terminal(neg)
and power supply ground
more or less
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
Copyright ©1999-2017 diyAudio
