#10921 |
A May 2008 6Moons review of the F5 shows a few pics of the amp interior. It appears that TH1 and TH2 are 2K2 (4K7 on the schematic), and R13 and R14 are 150R (47R on the schematic). Anyone know why the deviation?
#10922 |
ClothEar
Realy interesting question There is quite a bit I also do not know and get blown away by post such as Papa mention of P3 and post 10855 SCH show quite a few values changes Such as 0.68 source resistors and 10 to 1 relationship on the Imput resistors R13/R14 are100 homs in that one and few conection are different as well as the thermistors are after R7/R8 Papa said that almost any change would efect the way the F5 sound. I have tried P3 and left it out after blowing a couple of mosfets as Bias got realy hi even with a 10 turn pot and very small turn on it. I have to finish off a second channell with Cascode and 2 paralel J fets as mentioned in another post before I can post my listening impressions on that change. So far I can say that the first channel on which I made the change sems to have less distorsion and lover gain but this is based purely in what I can ear as my knolledge of electronics is wery limited. As I am etching my own boards is quite easy for me to put a few extra pads in and try things out. But like you I would realy apreciate if we could get same pointers on the caracter of those "small" changes |
#10923 |
Hi Huseyin,
One thing I would do is find some discrete diodes (fast, soft recovery types) and discard those KBP block bridges that do add a definite "edge" to the sound that's nearly impossible to get rid of. I assume there are 4 Kendeils 47,000uF caps? What are the black 470uF/200 Daewoo caps for? If you're going to mount the power fets to the top flat bar that's holding the 2 seperate heatsinks together, there is quite a bit of added thermal resistance between the plate and the heatsink - suggest using a smaller bar, or angle bracket, to hold the top and bottom edges of the heatsinks together and fasten o/p fets to heatsinks directly - more efficient and simpler. Also, the angle bracket can be used to mount the bottom and top covers. ... just my 2 cents.
... jh |
#10924 |
Are Q3 & Q4 still being biased at 1.3 amps in this revised F5 circuit (F5 Amplifier R1; 7/30/2008)? Am asking as that answers the question as to what voltage drops to look for across R7 & R8 when adjusting P1 & P2. (1.3 A * 0.68 Ohms = 0.88 V)
Thanks |
#10925 |
Bksabath: thank you for pointing out the R1 schematic.
#10926 |
ClothEar you welcome.
dnewman About R7 R8 I have tried 0.22 Homs Futabas MPC 74 with Paralell Toshibas as I was biasing each at over 2 A and the 0.47 Where a bit hot, sound wise all was fine (IMO I like farchild sound better). I am not going in the math for it as there are much better "professors" around here but I would wach out for the power rating of those. Last edited by Bksabath; 28th August 2011 at 09:04 AM. |
#10927 | |
I think the fast diodes will be better. I just have 2 kendeils,but ı can add the 10,000uf caps,I put the black caps instead of 4700uf 25v by mistake. yes I'll mount the outp. fets as you first said. I'll keep in touch the forum on my project.
Hüseyin Güngör |
#10928 |
I have a lot of BYT56G and BYV36C.Where can they be used for?Maybe in a preamp of F5?Thx
My New and vintage capacitor store: http://stores.ebay.com/Paradise-of-H...dio-components |
#10929 |
AVR & PIC C Dev.
In tube preamp PSUs.
#10930 |
Hi, I'm a long time lurker who's just finished reading this thread and I'm putting the finishing touches on my first F5 build. I have a little confusion to clear up before I put the "firstwatt" to my build. My build is on Peter Daniel's version of the PCBs and I bought the bits and pieces from TechDIY as "F5 kits". The Peter Daniel's board follows the original schematic, but the TechDIY kit is for the "R1" version. It was no problem to put a couple jumpers to modify the Peter Daniels board to follow the "R1" schematic and then install my "R1" parts kits. ![]() ![]() Two questions before I risk some smoke. What is the function of R1 (4.7k) on the new (left side) schematic ? The input resistor divider R9-R10 of the original (right side) schematic has changed in the new drawing. Should I jumper my board to match the new "R1" schematic for the connections of R1 (4.7k signal input resistor) ? I'm not understanding what current flows through R1 as drawn and what it's function is ? I'm guessing the only difference in the initial set up of the original and "R1" version is to center (measure) the P3 pot prior to power on ? Any other caveats ? Is P3 useful for anything other than changing the harmonic distortion distribution ? Thanks for any advice, and thanks especially to NP for the design and all the regulars for this entertaining thread, even though it is a bit long. It has been kind of like a long novel with a surprise twist to the ending. The new "R1" version schematic cleared up all kinds of "WTF" on my part, as I compared my boards to my parts kits and read the first thousand pages or so.
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| Page generated in 0.52434 seconds (100.00% PHP - 0% MySQL) with 10 queries |
