Old 15th August 2011, 12:30 PM   #10901
tinitus is offline tinitus  Europe
if you want optimal sound quality, avoid all magnetic materials
and keep all kinds of metal far from trafo
not even copper, no nothing
now, if you have severe noise problem, then may be different issue
and I guess most of us have
in these times with computer switchmodes everywhere
Old 15th August 2011, 01:18 PM   #10902
Snokker is offline Snokker  Netherlands
Snokker's Avatar
If that would be the case you can't even mount a toroid in a metal housing...
There's no magic involveld with shielding transformers, some manufacturers have "audio grade" toroids with grounded metal film shields at the outside.
Noise problems with toroids are often caused by harmonics on the mains and because of the high bandwidth of toroid you also see them secundairly... Odd harmonics on the neutral of the mains (3rd, 5th etc.) is indeed a problem, and the only solution is filtering (or throwing out all inverters, led lighting, also at the neigbours )
Old 15th August 2011, 02:16 PM   #10903
Marra is offline Marra  United Kingdom
Originally Posted by jimbo51 View Post
But make sure it's clean inside or the amp may sound a bit crumby
That takes the biscuit
Old 15th August 2011, 05:53 PM   #10904
Itsmee is offline Itsmee  England
Itsmee's Avatar
Originally Posted by Bksabath View Post
Now for the easy answer why not try a biscuit tin ?
That tin should make it sound sweet
Old 15th August 2011, 10:40 PM   #10905
DJNUBZ is offline DJNUBZ  United States
You guys are terrible
Old 16th August 2011, 10:34 AM   #10906
umut1001's Avatar
someone says adding an old transformer to the output of amp makes sound like sweety tube amp
My New and vintage capacitor store: http://stores.ebay.com/Paradise-of-H...dio-components
Old 16th August 2011, 06:22 PM   #10907
The one and only
Nelson Pass's Avatar
That really depends, but it's always interesting to try and see what you get.
Old 17th August 2011, 06:26 AM   #10908
umut1001's Avatar
I think so.It may change sound character.My mum sold my 4 old transformers for just 6 USD They weigh about 20 kilograms. Too many copper is gone also
Old 17th August 2011, 03:12 PM   #10909
The one and only
It will definitely change the sound character, the only question is whether
you will prefer it that way.
Old 18th August 2011, 01:35 AM   #10910
Is this like adding a choke load the o/p stage? Two seperate bifilar windings, maybe?
... jh
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
