F5 power amplifier - Page 1086 - diyAudio
Old 9th August 2011, 03:23 AM   #10851
sangram is offline sangram  India
Similar thing happened to me once when the lead connecting one of the power transistors worked loose. A huge, momentary pop. Later figured that even if one output goes bust and the other is fully conducting, offset is maintained close to zero. The speaker does see close to rail voltage at the instant of the fault, but only for a half second.
Old 9th August 2011, 06:30 AM   #10852
vtr is offline vtr  Switzerland
results
with resoldering the resistor (i use to 220 style power resistor for feedback, but couldn´t fit it in the pcb holes so i did solder it to -lötnägel- in german no idea if soldering nails is a correct translation so maybe i did some bad solder work and the fault was only the bad contact-because when i turned the amp of the resistor was outside of the amp...)
but the amp was fine. nothing blown so maybe all was my bad craftmanship?
i tested then the current limit circuit and found that it limits the current perfect down to 2 ohms, with 1 ohm it starts to oszillate when cutting of-is this a behavior of the irfp240/9240 or the circuit itself?
an additional result of my testing was that my transformer or the filter choke induces hum to my speakers even when not connected to the speaker itself, these l´s have quite some magnetic pickup in the filter network of the speaker
Old 10th August 2011, 08:12 PM   #10853
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Default dc offset
I'm attempting to bias one of my channels again.
I'm seeing 0v at the speaker binding posts (dc offsets) - - maybe I'll have to adjust my meter.
I know I should be approaching zero as R11 + R12 get inline - but to start with 0v?
Old 10th August 2011, 09:09 PM   #10854
The one and only
Nelson Pass's Avatar
Originally Posted by cyclecamper View Post
Perhaps for targetting human perception and processing an amp with higher basic distortion figures may actually be not just plesant but more "accurate" where it matters to human hearing.
Easy enough to explore this with the F5. Just adjust P3 to get out of the
2nd harmonic null and take a listen.
Old 10th August 2011, 09:27 PM   #10855
flg is offline flg  United States
flg's Avatar
P3?
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 11th August 2011, 12:08 AM   #10856
The one and only
Hasn't this been around?
Old 11th August 2011, 01:44 AM   #10857
jackinnj's Avatar
Uhhh, nope.
On the boards I had burned for myself I provisioned using alternative source resistors which effects the same result.
Old 11th August 2011, 05:21 AM   #10858
The one and only
Silly me.
Old 11th August 2011, 07:13 AM   #10859
Default is it worth upgrading Mr Nelson?
i see the different thermistor arrangement and some k2 balancing circuit-maybe only to implement the p3 as a easy fix?
thanks
Old 11th August 2011, 12:07 PM   #10860
Banned
Just when one had read the manual at least 76 times and mastered every single and and if
Papa came along with a new thing.
Is going to take me at least a week to understand the P fortunatley I am a bit beter with numbers and the 3 should only take a few days.
Magic
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2017 diyAudio
