Old 13th July 2011, 04:29 AM   #10771
tinitus is offline tinitus  Europe
Originally Posted by cyclecamper View Post
Not true if the heat conduction of the electrical insulator is relatively poor.
with classA, I hope its not
are you forgetting that with added heat spreader you have yet another material, and yet another connection
that itself would result in loss of heat transfer
this have been debated for year now
I'm surpriced noone haven't shown any data to prove efficiency of heatspreader
shoudn't be too hard
Old 13th July 2011, 06:18 AM   #10772
h_a is offline h_a  Europe
h_a's Avatar
See it as electrical circuit - if you use a single small resistor or many large ones in parallel does not matter.
Think in terms of flow, if you impede small flow with a large area with little resistance it's the same as impeding it a strong flow with a small area and high resistance. Because in the end, what matters is only the amount of power (power density times area) and heat resistance (constant value). Changing the power density by changing the area does not affect the product of the two.
Anycase, discussion is academic, copper always looks better
Hannes
Old 13th July 2011, 10:14 AM   #10773
That is exactly what the manufacturer does inside the power package to improve heat transfer and reduce thermal impedance.
this conclusion is complete rubbish.
regards Andrew T.
Old 13th July 2011, 10:16 AM   #10774
Ha,
I am struggling with your various thermal terms and trying to get the logic to fit my understanding of heat flow.
Could you define what your terms are/mean?
regards Andrew T.
Old 13th July 2011, 02:04 PM   #10775
erpiii is offline erpiii  United States
Default Copper Spreader
This is what I'm doing with my F5 copper to aluminum heat sinks. I have decided to isolate the output transistors so I am using 2 of these on each of my monoblocks. I am using diamond paste to attach the sinks to the copper bar. I will also be using diamond paste at the transistor on the copper bar as well. The heat sinks are mounted in compression using valve springs at around 180 psi on the inside of the heatsink. This should cancel out any thermal expansion differences between the copper and the aluminum. I also don't know too much about about thermal dynamics so I went for the brute force approach; not to mention getting a price break on the qty of heatsinks I purchased...
Old 13th July 2011, 10:39 PM   #10776
Default optimum preamp for Pass F5
Hi, I hope I am posting in the right place.
I'm getting ready to start a diy build from nothing. So, I have no limits whatsoever in selection of my project (speakers, too). I have been lurking for quite a while, and it looks like the Pass amplifiers are very well supported and liked on this forum. So, I think I am going to build one.
My dilemma is matching the preamp to the amp. I see in a number of threads that the pass F4 is commonly matched with the Impasse tube amp and the Pass Pumpkin preamp.
I am also considering building an F5, I think I would actually prefer to build the F5. However, I don't see any consensus on which preamp is optimum for it. Maybe it is not a big deal...just use any old preamp? B1? Impasse? Pumpkin? Heretical?
Thanks in advance for any advice.
Andy
Old 14th July 2011, 06:10 AM   #10777
h_a's Avatar
Sure;
power density=heat flow/area=amount of heat energy** per second per m^2
heat resistance=1/thermal (heat) conductivity -> heat transfer equivalent term of a resistor, defines the temperature difference created when a unit heat flow is conducted (unit: degree Celsius per Watt). From the unit one can see that this property does not depend on the area or power density, only on the heat power transfered. It does not bother wether its a large area with low power density or a small area with a large one.
Hope this helps! Hannes
**heat energy=power dissipation of the fet in this case
Old 14th July 2011, 06:17 AM   #10778
regiregi22's Avatar
Andy
Quite some people like to match it with the Pass B1, or its improved DC-coupled version DCB1.
There may be no such a thing as a best preamp for it, some people like a tube flavour, others like whatever-is-it while not having OPAMPs...
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 14th July 2011, 07:59 AM   #10779
Marra is offline Marra  United Kingdom
I can certainly recommend Salas excellent DCB1; even better when used in conjunction with an LDR type attenuator.
Salas hotrodded blue DCB1 build
Lightspeed Attenuator a new passive preamp
Andy
Old 14th July 2011, 08:37 AM   #10780
regiregi22's Avatar
I use the same arrangement, DCB1 with an LDR attenuator
I'm a happy user
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
Dennis Hui, Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.21216 seconds (68.64% PHP - 31.36% MySQL) with 11 queries
