F5 power amplifier
F5 power amplifier
Old 26th June 2011, 10:58 AM   #10711
_henry_ is offline _henry_  Australia
i second that.
i used beyma12cx and alpha15, with f5 for beyma and symasym for the alpha.
they are great.
cheers
henry
Old 26th June 2011, 11:12 AM   #10712
EUVL is offline EUVL  Europe
Normal CD has 2V rms output (single ended), so +/- 2.8V pk-pk.
Say you need some sort of volume control (I certainly do), minimum 6 db, pure passive.
That reduces the input to the F5 to +/- 1.4V.
The F5 has a gain of 6, which means 8.4V.
The standard F5 should has maximum output at around 20V, a balanced F5 with 4 FETs at around 12V per side.
Still quite some room from 8.4V, don't you think ?
Patrick
Old 26th June 2011, 11:21 AM   #10713
R.I.P.
A CDP is generally 2Vac to 2.2Vac, near enough 3Vpk or 6Vpp.
An F5 gain of 6 times gives speaker voltage of 18Vpk, or 36Vpp. That is very close to maximum power.
regards Andrew T.
Old 26th June 2011, 08:17 PM   #10714
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Default need help
I replaced my mosfet Q4, R14, r16, & 18 ( &R11 + R12) because my amp blew r14, and blackened R11 & R12.
I've hooked it up again, but I'm getting no voltage (.000v) across R12 when I attempted to check the bias.
So I'm guessing one of the transistors isn't functioning? Would it be Q2 or Q6 that powers that mosfet?
Old 29th June 2011, 12:12 PM   #10715
Ok, I think I know why I blew up my amp.
I had a ztx550 instead of a ztx450 in my circuit.
I'll need to find some ztx450 for my F5. Does anyone have any spares?
Old 29th June 2011, 01:03 PM   #10716
jackinnj is offline jackinnj  United States
jackinnj's Avatar
F5 power amplifier
PM Me, I can send you some.
In the interim, you can disable the protection circuit and still run the amp if you set up the bias carefully.
Old 29th June 2011, 04:29 PM   #10717
ljm_ljm is offline ljm_ljm  China
Summer is hot. Mr. PASS had designed a CLASS B amplifier equipment? My whole body is sweat
Old 29th June 2011, 06:46 PM   #10718
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Incursions into class D
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 1st July 2011, 03:02 PM   #10719
Default f5 cviller 1.0
I really missed the boat on Q5 & Q6. I've got the right transistors in place but I've got them backwards I believe.
The bubble on the circuit board aren't correct right? I've orientated my transistor towards the bubbles.
I'll have to clip them out and pop in some fresh ones and make sure they're in correct before if blows up on me again.
Old 1st July 2011, 04:36 PM   #10720
udailey is offline udailey  United States
Passive Aggressive
F5 power amplifier
Not sure which transistors or which board you mean, but is it possible that the transistor must be mounted from the back side of the board?
purchase LDRs anytime Also try my Resistor Replacers or LDR based Input Selector Email me. diyldr@gmail.com
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
