Old 20th June 2011, 08:17 PM   #10701
Nelson,
I have just had an inquiry about resistor selection for an F5. Looking at the THD plot (Figure 9 http://www.firstwatt.com/pdf/prod_f5_man.pdf) I was wondering if you also ran these curves at a lower frequency to see if the third harmonic distortion was a thermal artifact indicating a resistor type source?
ES
(Yes I am too lazy too look at all of your .25 zillion posts to see if this has been addressed. )
Old 20th June 2011, 10:08 PM   #10702
The one and only
Nelson Pass's Avatar
I did not, but the answer is that the 3rd harmonic is primarily a function
of the transistor characteristic.
Old 20th June 2011, 10:12 PM   #10703
udailey is offline udailey  United States
Passive Aggressive
Nelson, Which schematic editor do you use? I like the looks of your schematics. Sorry for OT but I bet other guys are a bit interested to.
Uriah
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 20th June 2011, 10:36 PM   #10704
Thanks for the prompt reply.
Based on my resistor measurements I would suspect that at around 10 volts the distortion from the Panasonic resistors of the types I measured would begin to be dominant as shown used in this applications feedback loop. Not sure of your exact choice other than you mention Panasonic.
Just curious, as I suspect modern designs are getting good enough that such issues are emerging.
Old 24th June 2011, 10:48 PM   #10705
TheAnaesthetist's Avatar
Default F5 hum, only one channel.
My F5 is now at service for 2 months. At the beginning I noticed a hum, only at the left channel and only audible when I put my ear close to the speaker. So no problem I thought. Sound is fantastic.
Now I planned a bias Vdc check last week and after this the hum changed . Adjustment were small, Vdc around +/- 10 mV and measured V sourceresistor is 0.6V, but the character change of the hum was big. After switching on the "cold" amp there is silence at first from the left channel, that's new. Seems good but after a few minutes suddenly it starts humming, first like a engine sputtering but then constantly and only the left channel. Not loud but audible. Tried to measure it: left 9 mV AC, right 0.5 mV AC. Sometimes after a while when the amp is more hotter it stops. This is suddenly worse than before. Guess it's not a grounding issue, right? Anyone an idea where to start? TIA
Joffrey
Old 24th June 2011, 10:56 PM   #10706
juma is offline juma  Serbia
juma's Avatar
Originally Posted by TheAnaesthetist View Post
... Anyone an idea where to start?...
google for "cold solder joint"
Old 25th June 2011, 08:40 AM   #10707
Thanks Juma, for your quick respons. After a short phase of denial (me, make a cold solder point ) it makes sense. So ... I have to resolder all connections left channel, I guess. Nice weekend job.
Old 26th June 2011, 10:32 AM   #10708
is F5 good in reproduction for rock music mainly? If so, what preamp would you recommend? SS or tubes?
Thanks.
Old 26th June 2011, 10:39 AM   #10709
CD and similar high output sources can drive an F5 to almost maximum power.
You don't need a pre-amp.
Lower level sources will need more gain than can be provided with a buffer for incapable sources.
Old 26th June 2011, 10:46 AM   #10710
_henry_ is offline _henry_  Australia
i second that.
i used beyma12cx and alpha15, with f5 for beyma and symasym for the alpha.
they are great.
cheers
henry
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2013 diyAudio
