F5 power amplifier
F5 power amplifier
Old 9th May 2011, 02:14 AM   #10601
6L6 is offline 6L6  United States
6L6's Avatar
F5 power amplifier
Originally Posted by merlin2069er View Post
I'm using 5x20mm 2.5A fuses (slow blow) for my F5. I just popped one with my transformer and bridges hooked up into the power supply unit.
I tested each primary side of the transformer to the outputs of each bridge ok.
I might have a short somewhere in the power supply I guess.
The most logical place to start is to make sure that you have each of the primaries connected properly, and then double check that the secondaries are also connected proper.
You should have continuity between the each black and red primaries, and the same on the green/blue secondaries. If you have any wire mis-connected, it will screw up half of the transformer, and pop the fuse.
Photos of your build would be very helpful to assist in troubleshooting.
Here are some pictures of the connections in various builds -
Note the 'A' and 'B' primaries are the twisted pairs.
Old 9th May 2011, 08:30 AM   #10602
Marra is offline Marra  United Kingdom
F5 power amplifier
Follow Andrew T's guidelines and use a bulb tester it saves a lot of hearache.
Old 9th May 2011, 08:29 PM   #10603
TheAnaesthetist is offline TheAnaesthetist  Netherlands
TheAnaesthetist's Avatar
Default F5 finished
I finished my F5 today and it is working properly. Adjusted now at 90% of target Iqs for a few days to come and than I will test it again. Sound is already great. I am a happy man!! Thanks Peter Daniel for your pcb's and all your advices, h_a for the matched transistors, Zen Mod's very practical initial testing manual an of course mister Pass for giving us the scheme. Enjoying time started. Here are a few pics.
Old 9th May 2011, 09:00 PM   #10604
NYCOne is offline NYCOne  United States
Originally Posted by Nelson Pass View Post
Who summons the JFET genie?
Can I call the MOSFET genie about cascoding outputs of an F5?
Old 9th May 2011, 09:15 PM   #10605
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
not Mosfet Genie itself but resident Court Jester
you don't need cascoding outputs on F5
just keep each one in safe area regardng dissipation and - if you need more overall dissipation - double number of outputs
they're more than capable , voltage vise
possible benefits from cascoding are smaller than harm induced by voltage losses
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 9th May 2011, 10:11 PM   #10606
just keep each one in safe area regarding dissipation and - if you need more overall dissipation - double number of outputs
You may not have seen my earlier post, I want to use Toshiba 2SK3497/2SJ618 at least in single, and perhaps as multiple outputs. They have a high Ciss. I'd like to cascode in any case. I haven't seen much if anything about cascoding F5 outputs. I could be going down the wrong path, but it seems like cascoding might help in this case.
Do you have any thoughts on cascoding the output Mosfets on the F5, it opens up a lot of possibilities.
Old 9th May 2011, 10:49 PM   #10607
alazira is offline alazira  United States
alazira's Avatar
The top row red/black wires look to be a half mm from shorting in that picture.
Old 9th May 2011, 10:52 PM   #10608
Zen Mod's Avatar
F5 power amplifier
patent 5343166
fig. 5
use PAT2PDF - Free PDF copies of patents: Download and print!
set cascode to have at least 15V across each gain mosfet
edit - disregard additional current sources across gain mosfets on Fig.5
Old 9th May 2011, 11:02 PM   #10609
flg is offline flg  United States
flg's Avatar
Yes, cascoding could probably provide the best sound with the transistors your speaking of. The downside is going to be when you figure out how much heat sink and power supply you'll need and how little the power output is. you'll need something like twice the rail voltage. That probably will be twice the power dissapation to get the same output power as a pair of IRFs or Faichilds. They probably work better at higher voltage too!
It's not usually done for those reasons. Having said that, I would say your biggest bang for the buck, is higher bias with more heat sink.
"It was the perfect high end audio product: Exotic, inefficient, expensive, unavailable, and toxic." N.P.
Old 10th May 2011, 12:19 AM   #10610
I guess I'll try them as a drop in replacement to the 2SK1530/2SJ201s and see what happens.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 11:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 06:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 11:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 09:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 05:06 PM
