| Thread Tools | Search this Thread |
#1051 |
I used the largest Conrads, but these should work if tall enough or use two 8.5" sections side by side and 8-12" tall.
Ebay heatsinks cut to order I also used that Plitron and it's a nice transformer for this amp. Tom |
#1052 |
Do you guys use 1- 18+18v, 8 amp transformer for 2 channels?
I build, therefore I am. |
#1053 |
I plan to use Plitron 18V+18V@8.33A (300VA) p/n 077014201 also for 2 channels. Currently I have 2 of those in my F4, but one actually works just fine. I think Nelson indicated awhile back in the thread that I should be ok with one of those for a stereo F5.
Tom |
#1054 |
You guys don't think there will be cross-talk between the 2 channels? For example, the Zen amp require only a + supply, so using 1 transfo with dual supplies worked ok. The F5 requires a + & - supply. Just want to get your thoughts on this.
Thanks, Vince
#1055 |
There should be no problem with this at all.
#1056 |
The one and only
The crosstalk I got was so low that I couldn't measure it
reliably. |
#1057 |
Ah!
What is generally the main culprit for crosstalk? or should I say : what make F5 immune for xtalk? Manu |
#1058 | |
#1059 |
The one and only
The channels are well separated, and the grounding is good.
#1060 | |
weed? ![]() (every new user of F5 will find a small bag in it ...... so in case of selling it ( God forbid!) , remember to pay it forward ......)
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
| Currently Active Users Viewing This Thread: 3 (2 members and 1 guests) | |
| Dennis Hui, Bksabath |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| Page generated in 0.17914 seconds (64.56% PHP - 35.44% MySQL) with 11 queries |
