F5 power amplifier
F5 power amplifier
Old 11th February 2011, 11:11 AM   #10301
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
Jaccolina - grumpy these dayz ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 11th February 2011, 11:28 AM   #10302
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Very, haven't had a smoke in 40 days.
(Knarf could at least put in an effort to read the last page of a thread, before jumping in after 7 years walkabout from this forum)
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 11th February 2011, 12:47 PM   #10303
Knarf is offline Knarf  Denmark
Knarf's Avatar
I'm sorry, I was trying to help.
60 seconds?
"A rough estimate for the diode bridge power dissipation would be 3 times load current times 0.75V per diode per channel. Factor of three needed because we have to correct for the non-sinusoidal current through the transformer secondary."
Roughly a minute, more or less.
Remember now why I hadn't been active here for the last 7 years...
Team Thermionic
Old 11th February 2011, 11:24 PM   #10304
Ryssen is offline Ryssen  Sweden
Ryssen's Avatar
I wrote a while back about my F5 starting to oschillate when I connected it to my DIY DAC with output trafo.
Yesterday I got the idea to ground the nehative side of the outputrafo (DAC)
and the oschillation stops....
How and why?
Old 13th February 2011, 07:55 PM   #10305
Woody1911a1 is offline Woody1911a1  United States
hey guys , < newbie at electronics here , but learning . i'm gathering the stuff for my f5 and really want a front switch and want it to be attractive .
i've read about others using this switch BULGIN|MP0045/1E2BL012|SWITCH, PUSHBUTTON, DPDT-2CO, | Newark.com rated at 3a @250v , which i'd really like to use , but wondering if it might be marginal if even acceptable to direct switch the ac for an f5 .
thanx in advance
Old 13th February 2011, 08:53 PM   #10306
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
F5 power amplifier
well, I like to mount my power switch in the bottom plate
in one corner, close to front plate
and run my power cords directly to there, from outside
less AC cord running inside the box
with the switch being invisible, no need to be fancy
and then you can choose a tougher one
Old 13th February 2011, 09:16 PM   #10307
in the bottom plate ? so you go over to your setup-up and lift up your amp to turn it on ?
geez i guess i am getting fancy wanting to turn mine on with a switch on the front
Old 13th February 2011, 09:23 PM   #10308
F5 power amplifier
no, ofcourse not
big feet
Old 14th February 2011, 02:48 AM   #10309
sangram is offline sangram  India
Lots of European companies do this (Ayon comes to mind), the trick is to mount it sideways. It anyway needs just one finger
I put mine on the backplate. Just leave it on all the time, and switch it from the mains outlet. Some of my P2P ones don't even have a switch.
The trouble with a switch on the front plate is that either you have to have a thin plate, or recess the mount so the switch will actually clip correctly. I tried valiantly and then decided to move it to the back.
Some amps have a retro-style rotary power switch. That's really cool too.
Old 14th February 2011, 12:05 PM   #10310
F5 power amplifier
great looking toroids
anyone like the idea of a new F5 thread
F5, parts only ?
maybe someone else want to jumpstart it ?
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
