Old 3rd February 2011, 08:00 PM   #10251
flg is offline flg  United States
flg's Avatar
I use a product called "Solder Wick". It is essentially a fine braid with flux imbeded.
“Be who you are and say what you feel because those who mind don't matter and those who matter don't mind.” Dr. Seuss
Old 3rd February 2011, 08:12 PM   #10252
tinitus is offline tinitus  Europe
if components are going to be dumped/changed, cut the legs first
then remove the pieces, one by one
and then begin to clean the board and holes with solder sucking braid
some times holes can be tricky
then I have inserted a sewing needle into the melted solder
or used compressed air
but be careful
solder braid need lots of heat
some components might not like it
Old 3rd February 2011, 08:36 PM   #10253
regiregi22's Avatar
Originally Posted by Marra View Post
Solder braid it is then
It's a matter of choice, I prefer to use a solder sucker. Just heat the solder, get the tip of the sucker onto the solder (the tip is heat-resistant plastic) and push the button. clean of solder in a second. CLeaning holes is A LOT easier with this.
http://upload.wikimedia.org/wikipedi...der_sucker.jpg
I would get both, they are cheap, and choose one or complement them for different situations
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 3rd February 2011, 10:20 PM   #10254
Kilroy is offline Kilroy  United States
Default Remote power trigger circuit: In the amp?
While I'm waiting for my heatsinks, a thought came to me about my build plan I wanted to run by you all...
I have a 12v trigger from my head unit that I planned to utilize to turn on my 2 F5 stereo amps. I had a simple relay circuit planned...
But now I'm wondering if it might be a bad idea from a noise perspective to house it in the amp itself. Maybe building a power strip with the circuit built into that would be the better choice.
Do you guys think a trigger circuit might insert noise in the amp?
How would you mitigate that possibility?
I made smoke!
Old 4th February 2011, 12:25 AM   #10255
Originally Posted by udailey View Post
Nikon
WOW.
Great offer. Very friendly offer.
I hope you go ahead and do so.
Uriah
So my plan is the following:
1) I will make a draft table of content and post it for comments.
2) When this is almost accepted I will start putting the beef inside and chapter by chapter send it for revision.
I really wanted to contribute in some way, as I do not have the knowledge to produce brilliant circuits, at least I can let people that have this knowledge have more time to do it, instead to answer always the same questions.
As a general approach, I am not aiming to make a bible: if explanations or options are disputed I will just write the various possibilities, and "let people chose their own poison" (quot. ZenMod)
As NP says "This is the entertainment business, and I hope everybody is having fun"
Davide
Old 4th February 2011, 04:15 AM   #10256
bear's Avatar
Originally Posted by AndrewT View Post
Damping Factor is a measure of the output impedance of an amplifier.
Source impedance does affect the speaker Q and this results in a different bass response.
Please show us the explanation of how and why DF gives the apparent bass report that was posted earlier.
Both explanations could be valid, one may be more plausible than the other.
That is no reason for expressing "Bah"
Andrew, my friend from the British Isles, Scotland is it?
Anyhow, it sure as heck ain't the difference in frequency response below 5Hz. is it?
I didn't look at the Hafler spec, but it's likely down around 1Hz...
So, 1Hz. vs DC that's the cause??
Higher DF usually gives the report of "tighter" or "thinner" bass, while lower DF usually gives the report of "looser" or "fatter" bass - of course depending on the Qt of the speaker system, and the room response.
Since we don't know the poster's set up, we can speculate. But you can explain to us how sub-sub-sub bass frequency response is going to make a difference in the report of the bass?
Perhaps you are right!
_-_-bear
_-_-bear
http://www.bearlabs.com ...ur feeback please - like/dislike my what I have written? PM/email tnx. --
Old 4th February 2011, 08:12 AM   #10257
Marra is offline Marra  United Kingdom
Thanks for the responses. I originally used solder braid then switched to a solder sucker but never quite seem to be able to suck all the solder out on boards with vias.I'll start and use both from now on.I'm well on the way to stuffing the spare pcb so hopefully be able to set it up this weekend; just hope this time I can set the bias correctly.
Old 4th February 2011, 09:51 AM   #10258
h_a is offline h_a  Europe
h_a's Avatar
Not so amusingly the usual cheap solder suckers are not temperature regulated or whatever at all. They cook happily and also need care to use them. Can destroy pads in seconds
Personally I always use desolder braid for anything smaller than, say, TO-247. The cooker takes care of the big ones.
Hannes
Old 4th February 2011, 10:17 AM   #10259
bobodioulasso's Avatar
Personally, i continue to use the old solder containing lead, it melts at lower temperature.
One thing i do not understand is why DIYers prefer double layers PCBs for simple amps, which makes unsoldering unpleasant and tricky. Simple layer and larger PCBs makes life easy when you have to troubleshoot.
Old 4th February 2011, 10:28 AM   #10260
I whole heartedly agree this is the first time I think I have ever lifted a trace like I did with this one. Never had a problem with single sided boards.
Please do not take this as a criticism of cvillers pcb's which are of excellent quality this problem was down to my hamfistedness
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.20132 seconds (69.83% PHP - 30.17% MySQL) with 11 queries
