F5 power amplifier
F5 power amplifier
Old 31st January 2011, 12:30 PM   #10191
Marra is offline Marra  United Kingdom
F5 power amplifier
Sorry Andrew that did't work right; I'll try and do the link later.
I am using an 500VA transformer feeding +- 132,000uf through schottky diodes.
The nuisance fuse blowing I will check out tomorrow as I have to go out now.
Thanks Marra.
Old 31st January 2011, 12:42 PM   #10192
F5 power amplifier
Hi Andrew do I take it that as you did not pass comment regarding the resistance readings for the mosfets that they are ok?
Marra
Old 31st January 2011, 12:51 PM   #10193
500VA would normally use a T6A fuse to survive repeated start ups over the years.
With a soft start you can probably use an F2A if the resistor/s reduce the starting current sufficiently.
To use an F1A, I suspect you would need 3 CL60 in series and another 50r of Power Resistors to reduce the start up current and gradually bring it on line as the CL60s heat up.
With +-132mF you may want to consider slow charging. NTC are best for this, located in the secondary circuit and again bypassed when the CL60s have done their job.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 31st January 2011, 01:28 PM   #10194
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
F5 power amplifier
relays.......in secondary circuit ?
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 31st January 2011, 01:43 PM   #10195
anilva is offline anilva  India
Originally Posted by anilva View Post
Andrew,
I if were to add a input capacitor to the F5 to prevent inadvertent DC to creep into the amp, is a 1 mfd, MKP a good choice, without compromising the bandwidth of the amp too much?
Thanks in advance.
Just to clarify, I am asking if a 1uf mkp is a good capacitor value to block dc input to the f5. I am assuming 101k as the 'R' value of the input. I am not sure if 1/(2*pi*r*c) is the right way to calculate the high pass frequency for this setup.
TIA.
DIY F5, F5T, F6, Aleph J, Fostex 206 based BLH, Altec Onken with 515 LF & 288 HF, Technics SP10 MKII & EMT950 turntables
Old 31st January 2011, 01:48 PM   #10196
cviller is offline cviller  Canada
cviller's Avatar
Originally Posted by Marra View Post
Yes this is without the bulb connected. On the left channel P1 does not alter the reading across the source resistor. P2 I can adjust. I raised the voltage to 0.12V and the offset changed so I turned it back to its lowest setting. With the right channel connected the p/s voltage started to rise then the 1amp q/b fuse popped.
Hi Marra, this is most likely your problem. You need to adjust both P1 and P2 - don't just turn one of them all the way to the end. Don't worry too much about DC before you have the current dialled in on the .47 ohms.
Old 31st January 2011, 01:59 PM   #10197
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
My fote vor wet fingertips.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 31st January 2011, 02:31 PM   #10198
Zen Mod's Avatar
F5 power amplifier
und meine euch ......
Old 31st January 2011, 04:06 PM   #10199
F5 power amplifier
Thanks for the responses.
Andrew regarding the soft start I don't think theres any point in posting a link as there is no circuit diagram just pics of the pcb. I have been using one of these s/s in my Aleph 5 clone for the past 6yrs without any problem supplying 300VA transformers feeding +- 47,000uf per channel and a 2A slo/blo fuse.
Christian on one channel I adjusted P1 almost fully upwards without any voltage reading across the source resistor; P2 slowly raised the voltage upwards. The right channel when connected with the left disconnected blew the fuse. I was using a 1amp fuse which is what it says in the original article but having reread the article I realise it was advised in conjunction with a variac whereas I just turned the amp on. I guess I need to borrow a friends variac or try it with the reccomended 1.25amp slo/blo and see what happens.
Thanks again Marra
Old 31st January 2011, 04:32 PM   #10200
Zen Mod's Avatar
F5 power amplifier
you must iteratively turn one then other trimpot ;
while doing that - monitoring both - voltage across one source resistor and output offset .
while waking up one mosfet - other one is still sleeping , so current which can go through awaken one , have no possible path through other one ;
you wrote that you read powering up procedure .
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2017 diyAudio
