| Thread Tools | Search this Thread |
#1011 |
Lightning In A Bottle
Looks like Nelson decided 1.5A sounds better than 1.3A.
Quad Matched Toshiba 2SK1530/2SJ201 MOSFETs http://www.diyaudio.com/forums/swap-...ml#post2086375
#1012 | |
#1013 | |
Of course ! "Do It Yourself !" said the burning bush (it was on the second tablet - the one that Mel Brooks dropped) |
#1014 |
"Do It Yourself" and share your job...
Here my (very modest) contribute to the cause. The program is the well-known ExpressPCB. The imagine (copper side) is reversed, so is perfect for "laser printer and iron" technique. Guido |
#1015 | |
The one and only
do if the channel exceeds .005% at 1 watt. As I have said, you need an analyzer to be able to do this. A minority of channels need this, and it is random in value and placement. |
#1016 | |
If the Zen Master says so I supposedly that I drawed the circuit right
#1017 |
After I success full with Aleph J now I used GOFFE's model to be my next project of F5
#1018 |
Will ZTX450 more stable in compare with using MPSA18 ?
#1019 | |
Formerly "jh6you". R.I.P.
They would be sleeping, probably over the life of F5 operation... Forget their stability, grab any one and use it... |
#1020 |
Hi
Is the pair of 2sa970/2sc2240 will be a good replacement for ZTX450/ZTX550? |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| Bksabath |
| Rockford Fosgate Power 20001 bd amplifier power rating?? | pachoorion | Car Audio | 8 | 8th May 2011 10:49 PM |
| Power transformers versus amplifier output power..what is your option? | destroyer X | Solid State | 38 | 9th May 2009 05:23 PM |
| McIntosh Power Amplifier Power Guard | johnnyrt | Solid State | 2 | 23rd August 2007 10:22 PM |
| Output power for a power amplifier | Progg70 | Solid State | 33 | 10th September 2006 08:44 AM |
| Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality | MARAVILLASAUDIO | Class D | 1 | 5th November 2004 04:06 PM |
| Page generated in 0.16021 seconds (60.87% PHP - 39.13% MySQL) with 11 queries |
