F5 power amplifier - Page 1019 - diyAudio
Old 31st January 2011, 10:10 AM   #10181
Marra is offline Marra  United Kingdom
Thanks Andrew; I have the followng resistances:-
Left channel P device D-S 52.2R S-D 55.6R N device D-S 51.2R S-D 48.5R
Right channel P device D-S 69.5R S-D 83.3R N device D-S 71.5R
S-D 61.4R.
I am using Fairchild Mosfets.
Old 31st January 2011, 10:20 AM   #10182
bobodioulasso's Avatar
Marra, did you follow the right proceed for bias and offset setting?
That is without the bulb.
Old 31st January 2011, 10:27 AM   #10183
anilva is offline anilva  India
Originally Posted by AndrewT View Post
1mW is ~-47dB ref maximum power of the F5 (50W into 4r0).
If one had noise at a level of -47dB one would be in tears after spending all that money.
Output offset is a "noise", if anyone will allow DC to be a noise. It certainly should not be there and certainly not considered acceptable.
If high efficiency speakers are being used with the F5 then it's even more important to minimise the output offset.
Andrew,
I if were to add a input capacitor to the F5 to prevent inadvertent DC to creep into the amp, is a 1 mfd, MKP a good choice, without compromising the bandwidth of the amp too much?
Thanks in advance.
DIY F5, F5T, F6, Aleph J, Fostex 206 based BLH, Altec Onken with 515 LF & 288 HF, Technics SP10 MKII & EMT950 turntables
Old 31st January 2011, 11:09 AM   #10184
Yes this is without the bulb connected. On the left channel P1 does not alter the reading across the source resistor. P2 I can adjust. I raised the voltage to 0.12V and the offset changed so I turned it back to its lowest setting. With the right channel connected the p/s voltage started to rise then the 1amp q/b fuse popped.
Old 31st January 2011, 11:19 AM   #10185
AndrewT is online now AndrewT  Scotland
Originally Posted by Marra View Post
.........then the 1amp q/b fuse popped.
F1A?
Where is/are it/they located?
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 31st January 2011, 11:38 AM   #10186
Mains fused after the IEC inlet.
Old 31st January 2011, 11:58 AM   #10187
What is your soft start circuit?
Do you need a slow charge circuit?
regards Andrew T.
Old 31st January 2011, 12:04 PM   #10188
The soft start circuit is one I bought from Avondale Audio that uses series resistors and relays which switch on in two stages.
Old 31st January 2011, 12:07 PM   #10189
Disconnect your amplifiers from the PSU.
Discharge the PSU
Start up your PSU using the F1A.
How often can you discharge and restart the PSU without nuisance blowing of the mains fuse?
How much VA does the F1A start up?
Can you link to details of the soft start?
regards Andrew T.
Old 31st January 2011, 12:26 PM   #10190
Soft Start Module for Mains Supply
Avondale Audio soft start module
Fully Automatic Timing Sequence - No more dimming lights, pops, clicks or blown fuses!
Operates in line fully automatically or manually with a low current switch.
Handles up to 1KW.
Includes an on-board mains current breaker / fuse, spark suppression and transient clamping.
Size: 97mm X 72mm Plus, no soldering
Soft Start PCB
Avondale Audio TPX pcb
Available in PCB only form for DIY audio projects.
Comes with list of required components and building guide.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
