Old 31st January 2011, 04:13 AM   #10171
lhquam is offline lhquam  United States
Default To DC block or not, that is the question
I finally finished my F5 and decided that it was trustworthy enough to install in my stereo system (Squeezebox, McIntosh C504 preamp (circa approx 1986) and B&W CDM1 speakers).
I found that the offset voltage of each channel went to about 60 mv (from near zero) when connected to the preamp. Measuring the dc level of the preamps verified that the preamp channels have about 10 mv dc output. Apparently the 10uf non-polar DC blocking caps in the preamp are leaking a little.
My question is whether to simply adjust the F5 to accomodate that offset at the inputs, install blocking caps in the F5, or replace the blocking caps of the preamp.
Old 31st January 2011, 04:48 AM   #10172
1st things first - get your preamp sorted - [B].... replace the blocking caps of the preamp[/B] - good quality film ones will also give a big improvement in sound quality - film caps do usually take awhile to "settle down" to their final sound - also have a look at replacing all the other electros, as 25 years old.
... jh
Old 31st January 2011, 04:51 AM   #10173
Lerg is offline Lerg  Canada
Don't break your F5 to compensate for your preamp. Fix the preamp.
Old 31st January 2011, 05:20 AM   #10174
EUVL is offline EUVL  Europe
You can always give DC servo a consideration.
Old 31st January 2011, 05:47 AM   #10175
Maybe it is time to consider building a replacement preamp.
Old 31st January 2011, 07:59 AM   #10176
h_a is offline h_a  Europe
h_a's Avatar
60mV...that's about 1 milliWatt into your 4R speaker ;-)
Voice coil displacement must be in the micron-range.
I would say - enjoy your F5 and use the time to listen to music ;-)
Old 31st January 2011, 08:31 AM   #10177
1mW is ~-47dB ref maximum power of the F5 (50W into 4r0).
If one had noise at a level of -47dB one would be in tears after spending all that money.
Output offset is a "noise", if anyone will allow DC to be a noise. It certainly should not be there and certainly not considered acceptable.
If high efficiency speakers are being used with the F5 then it's even more important to minimise the output offset.
regards Andrew T.
Old 31st January 2011, 09:10 AM   #10178
Marra is offline Marra  United Kingdom
I connected up my F5 to the mains this morning without the bulb tester and after several seconds the fuse blew. The right channel was disconnected. The left channel did not blow the fuse but adjusting P1 does not do anything; P2 adjusts the voltage across R12 and alters the dc offset. Nothing went pop on the pcb's and there was no smoke. Have I cooked Q3 on the left channel? Any advice as to what to check would be much appreciated. TIA
Old 31st January 2011, 09:14 AM   #10179
Unplug.
Discharge all the capacitors with a power resistor.
The electrolytics will appear to recharge due to energy storage in the di-electric.
Discharge them at least twice and measure voltages before you start the next stage.
Measure the resistance of the Output mosFETs.
D to S and S to D.
regards Andrew T.
Old 31st January 2011, 09:25 AM   #10180
jpedro is offline jpedro  Portugal
Hi CViller,
I made an order for a PSU for the F5, and also the payment procedure.
Best regards,
Pedro Simões
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Bksabath
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Page generated in 0.18578 seconds (60.38% PHP - 39.62% MySQL) with 11 queries
