F5 power amplifier - Page 1012 - diyAudio
Old 25th January 2011, 05:33 PM   #10111
labjr is offline labjr  United States
Reminds me of that scene in Caddyshack.
"I want a hamburger, no a cheeseburger. I want a hotdog. I want a milkshake. I want potato sala--You'll get nothing and like it!"
Old 25th January 2011, 06:14 PM   #10112
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by viki_v2 View Post
very sorry for annoying you guys,
I got some helping ans here so kept on asking.
keep up the good work
Bye
It would have been of great help.
the point is, it will be a complete mess if we go too much off topic
members come to F5 thread to debate F5, and not something completely different
ask your questions in appropriate threads, and you will get proper answers
wish you luck
moderation
Old 25th January 2011, 07:03 PM   #10113
Bye
Hi viki,
please, run away from A class amps, go to AB, f.E:
Project 101 - High Power, High Fidelity MOSFET power amplifier
It's a very good amp, not expensive and not hard to build!
& for fun!
Old 25th January 2011, 08:02 PM   #10114
merlin2069er's Avatar
Send a message via MSN to merlin2069er
So, P1 & P2 should be set a minimal setting before powering up the F5?
I think I may have a cold solder joint, can't seem to get thing out of one of my P2 pots.
Old 25th January 2011, 08:40 PM   #10115
jackinnj's Avatar
Read this:
Your F5 blew up, now what do you do?
Why, silly hare, are you fleeing from the fierce jaws of the lion now grown tame?
Old 26th January 2011, 12:09 AM   #10116
alazira is offline alazira  United States
alazira's Avatar
Originally Posted by Nikon1975 View Post
Now this is clear, what about the matching story? I understood that the 5 ohm give an asymmetry to the circuit to compensate the difference of the devices. Then, how to choose them ?
Thanks,
D.
If you are planning on doing the 5ohm degeneration trick you need:
1) N-P matched mosfets for each channel.
2) 2SJ74 with an Idss about 1mA more than 2SK170
3) either add 5ohm resistor between the 2SJ74 source pin and the feedback node, or replace R with 15ohm and feedback of 75ohm.
All three steps are required.
Old 26th January 2011, 05:37 AM   #10117
EUVL is offline EUVL  Europe
Only if you want perfect even harmonics cancellation.
And the cancellation works for single ended F5 just as well.
Patrick
Old 26th January 2011, 08:54 AM   #10118
Marra is offline Marra  United Kingdom
I'm using Caddock MP930 resistors for the .47R and 50R feedback will 25C/W clip on sinks be big enough?
Marra
Old 26th January 2011, 01:43 PM   #10119
Maybe this is a silly question but...
All the cool guys with nice equipment make the tuning looking at the distortion at 1W. Now my USB scope, has a dynamic range that is limited to -90/-100dB. Good for tube amps, but with the F5 all the harmonics are buried. Can I do the tuning at 10 W ?
Thanks,
D.
Old 26th January 2011, 02:54 PM   #10120
use Cordell's distortion magnifier.
If that is not sufficient then consider a higher test frequency and/or a higher test voltage and/or a lower test load impedance.
If you still can't see it in any of the IMD tests then you probably can't hear it either.
regards Andrew T.
Sent from my desktop computer using a keyboard
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright 1999-2017 diyAudio
