Old 25th January 2011, 12:23 PM   #10101
On the other end, even with the pcb that I have (Cviller V1), it does not take much to stick a 5 ohm resistor on the source of the jfet. It sounds too simple, that's why I did not do it yet.
D.
Old 25th January 2011, 12:33 PM   #10102
bobodioulasso's Avatar
The jfets have to be chosen precisely also.
Imho, it's more interesting when balanced.
Old 25th January 2011, 01:13 PM   #10103
labjr is offline labjr  United States
Originally Posted by viki_v2 View Post
i know you are helping me, But i want a simple single layer pcb layout of at least 3 pairs of trannies. double layer will be a bit difficult for me as double side pcb not available here only single side.
If i want double side i have to travel 60 kms . If no option then i will make a double side version.
Also ther are so many versions i am a bit confused. i need output of 200 watts at 8 ohms.
Why not just go for 12,000 watts? Solid silver wound transformers all in a case carved out of a 400 lb billet of solid gold encrusted with diamonds and rubies and sapphires?
Do you think this forum is a genie in a bottle? How about building the original circuit first before you dream up something you'll never finish?
Old 25th January 2011, 01:50 PM   #10104
6L6 is offline 6L6  United States
6L6's Avatar
I agree wholeheartedly.
The F5 is universally loved by those who build it. You really should build one 'stock' and see how wonderful it is.
If you need more power, just build more and bi-amp or run monoblocks. There are a number of people who have done that to great success.
llustrated Build Guides - Pass Pearl 1 - Pass B1 - - Pass F5 - Pearl 2 - -O2 HPA - -
Pass F4
Old 25th January 2011, 02:49 PM   #10105
udailey is offline udailey  United States
Passive Aggressive
Oh Larry, there you go again with your Christina Aguilera quotes.
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com
Old 25th January 2011, 02:56 PM   #10106
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by 6L6 View Post
If you need more power, just build more and bi-amp or ....
Or in parallel And bridged.
Like for example this critter : http://electronics-diy.com/pdf/Sony_TA-NR1.pdf
The later edition TA-NR10 is basically the same, but an All-FET model, with one-off J201/K1530 output devices (2 times 5 pairs in each monaural amp)
Take my word that a parallel/bridged F5 doesn't sound inferior to a bridged TA-NR10 setup
Not so much,.......if it says "ZM" in the corner.
Old 25th January 2011, 05:00 PM   #10107
viki_v2 is offline viki_v2  India
viki_v2's Avatar
Guys i searched a lot , but not able to find pcb layout of krell ksa 100 can any one help.
I got pcb layout of krell ksa 50 but no component layout.
Old 25th January 2011, 05:08 PM   #10108
tinitus is offline tinitus  Europe
I think its a project for the experienced, and not a beginners thing
I suppose its pretty hot where you live
If so I wouldnt build classA
small one, maybe
but big one, no
for a first project I would not suggest amps with multiple matched outputs
in your own interest, find yourself a nice simple amp to build, to start with
if you hope to build a top grade amp there are a few things you need to learn first
its not something that happens in the first try
Old 25th January 2011, 05:14 PM   #10109
anilva is offline anilva  India
Viki,
This section of the forum is for discussing Pass amps and in particular F5 amp. For your queries and help regarding Krell and other such amps, you need to post in the solid-state section. You are only going to **** off people here, by continuously asking questions which this section does not address normally.
My request therefore is to do research and post if any queries in other relevant sections of DIYA.
Cheers.
DIY F5 Turbo V3, DIY F5 Turbo V2, DIY F5, DIY F5 Toshiba Dual output, DIY Aleph J, DIY Fostex 206 BLH, DIY Altec Onken with 515B LF & 288H HF, Behringer Digital Xover, Technics SP10 MKII & SL-1210, EMT938 TT.
Old 25th January 2011, 05:31 PM   #10110
viki_v2's Avatar
very sorry for annoying you guys,
I got some helping ans here so kept on asking.
keep up the good work
Bye
It would have been of great help.
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2013 diyAudio
