F5 power amplifier
F5 power amplifier
Old 19th January 2011, 11:12 PM   #10011
labjr is offline labjr  United States
Originally Posted by Kilroy View Post
Thanks for this!
So I'm sold on the HS USA sinks but I'm trying to figure out what length I need for each side of the stereo amps.
Do you guys think 8" is enough or do I need to go all the way to 12" like Labjr did?
Thoughts?
Well, Nelson recommends 96 sq in. per channel so I added a little more to be sure since I don't know how this particular heatsink will perform. I imagine a 10 in piece would be sufficient. I believe somewhere back in this thread someone tried a 7 inch piece of the same stuff and thought it ran a little hot.
Old 20th January 2011, 12:28 AM   #10012
Bksabath is offline Bksabath  United Kingdom
Banned
http://www.cooperbussmann.com/pdf/28...e536281e0a.pdf
Specs for fuses
It take times fo them to blow depending on the current
Supose 20 V rails and a mosfet Blow
You need the fault loop impedence to find out the fault current.
0.47 R the resistor on the source + wiring iside the amp + resistance of the power cord +resistance of the wiring inside the house+ resistance of the wires from your fuse board to the earting point of the distribution system.
say total impedence of the circuit 1 ohm 20V / 1 =20 A
You put the termistor on the ground to reduce ground loops ad the resistance to that and recalculate
Pick your fuse and folow the curve to where those 20 A cross the time.
I think you seen the wires on the coil winding on the speaker.
If you shure it will take it fine
If you don't know and don't care fine again.
On the third hand if you don't know and prefer to be safe ask.
Thats what I did and for shure a mosfet is faster than a fuse.
Will they take it fo that long
Old 20th January 2011, 12:39 AM   #10013
Banned
http://www.diyaudio.com/forums/attac...-sinks-001.jpg
My sinks black anodised now
300X400x83
But I got 4 ohms speakers and may build B2 or aleph once I have finished the F5 balanced
Old 20th January 2011, 11:45 AM   #10014
Nikon1975 is offline Nikon1975  Austria
Thanks for this!
Thoughts?
My heatsinks in cm are 150*350 and the fins are 50mm. With 1.4 amp on each mosfet it get warm, but not hot. I use raw aluminum.
D.
Old 20th January 2011, 11:56 AM   #10015
R.I.P.
Default typo?
I can see they never get hot !
150cm*350cm would need a crane to install them.
What size are the fins? 350*50 or 150*50?
Are they aligned vertically for best air flow?
How thick is the backplate?
How have you attached the FETs to the heatsink?
regards Andrew T.
Old 20th January 2011, 12:07 PM   #10016
Sorry mm. What I wanted to say not inches.
Fins are vertically aligned.
D.
Old 20th January 2011, 01:28 PM   #10017
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
My heatsinks in mm are 150*350 and the fins are 50mm. With 1.4 amp on each mosfet it get warm, but not hot.
Small wonder.
Reads like a very nice heatsink.
Old 20th January 2011, 01:37 PM   #10018
it's the biggest that conrad has. 0.2 C/W if I remember well.
D.
Old 20th January 2011, 01:51 PM   #10019
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
Originally Posted by Bksabath View Post
Neutrality yes it may be but then you have loads of energy stored in the caps
Is the may be that scare me.
Don't you use to put bleeder resistors?
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 20th January 2011, 02:04 PM   #10020
regiregi22's Avatar
Tanks Neutrality
OK thats fine then
What the time response for the fuse say for example rated at 3A and the fault current is
say 30A ?
Look for the exact brand and model of the fuse and see it in their datasheet.
F5 power amplifierHide this!Advertise here!
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
