Old 15th April 2008, 05:31 PM   #91
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally posted by Nelson Pass
Here is the schematic. It does not include, of course, the discussion
on the function of the additional parts or how the values are
derived or what tweaks will be useful. Those of you with a copy
of the article are free to comment as you like.
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 15th April 2008, 06:11 PM   #92
Kovax is offline Kovax  Croatia
Thank You for the schematic Mr. Pass!
If it can't be fixed ... use a bigger hammer
Old 15th April 2008, 06:46 PM   #93
Thank you very much for the schematics. I now
eagerly await my issue to arrive.
Now that the schematics is available, I expect
Steen will have his version completed sometime
this evening...
Dennis
Old 15th April 2008, 06:57 PM   #94
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
I wish AudioXpress would have offered a free .pdf download of the
article when a 1 year subscription was purchased - something creative
like that.
The schematic doesn't mean much to me without the article!
Think how many new subscribers they could have gained!
back to being patient looking forward to the full article.
Old 15th April 2008, 07:03 PM   #95
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Send a message via MSN to lykkedk
Nelson, could you tell the secret , if the Varistor 4,7K (TH1 + TH2) is NTC or PTC, and if , will it be mounted on heatsink ???
Can't wait to see the full artichle.
Jesper.
DIYAudio crazy.... LeachAmp, PearlPhono, Pumpkin, F4 DualMono, DDDac, HalfChang Spk., LinuxAudio, Squeezebox substitute, Drek inductorloaded pre-amp.
Old 15th April 2008, 07:08 PM   #96
tms0425 is offline tms0425  United States
Thanks for the peek at the schema. As usual, the design is quite fascinating, but so simple in execution.
I wish my AudioXpress would hurry up and get here so I can digest all the 'splainin' there to make sense of it.
Tom
Old 15th April 2008, 07:24 PM   #97
EUVL is offline EUVL  Europe
> Those of you with a copy of the article are free to comment as you like.
Yes I am one of the lucky ones who got a copy. No I have not read it yet.
Since no one is volunteering, I shall stick my neck out. Hope my interpretations are correct, and Nelson will forgive me for speaking my mind. And I shall only attempt to comment on the differences between the simplified and the full schematics.
Starting from the input.
R9 offers some isolation to the source. R10 provides ground reference when not connected. Just good practice.
The drain resistor was 600 ohm in the simplified, so 1st stage bias was 6mA. Since the second stage is now degenerated (R11,12), the bias voltage has to be increased to 4.2V. So drain resistor 700R required. This is formed by R3, P1 and (R15+TH1) in parallel. Similarly on the -ve side.
P1,2 provide bias adjustment, but I would replace them with fixed resistors after trimming at temperature. TH1,2 appears to be a themistors (NTCs) for bias compensation during warm-up, assuming positive tempco of the MOSFETs (should be the case for the FETS named and the 1.3A bias). If so, they want to be thermally coupled to the power MOSFETs.
I personally do not like thermal compensation with thermistors. For one, it changes the open loop gain, and you don't really know by how much. Worst, you don't know whether the 2 halves drift and compensate symmetrically. So I would just take TH1,2 out and use R15,16 only if I were to build. The consequence is a bit lower bias when cold, and a small risk of thermal run-away. But I have the same (no compensation) in Aleph-X and never have any problems. But that is purely my personal choice.
Q5, R19, R17, R21 are for over-current and over-voltage protection. There was something similar in the Aleph schematics. And I also saw something similar before from Kaneda.
When voltage across V19 exceeds 0.6V, Q5 will shut off the MOSFET by reducing gate voltage to zero. So current limit is set by R17 & R19, provided a value for R11 has been chosen. Voltage limit is set by R21, R19, in case of a output MOSFET failure, e.g. Not must have, but nice to have. And since it is placed further from the gate of Q3 than R13, it should have no negative influence during normal operation.
R11,12 are source degeneration for the MOSFETs. John Curl mentioned on the blowtorch thread that source degeneration messes up the distortion spectrum. But I guess you need something for bias stability (a sort of local current feedback). And it provides a convenient means for current sensing (for protection). I find 0R47 a bit high, and would have gone for 0R22 or even 0R1. But that also depends on a lot of things like which MOSFET and how much heat sinking.
I wonder if Nelson would care to explain his choice.
R13, R14 are gate stoppers for the MOSFETs (to prevent oscillation). The values are quite low, but then it is supposed to be a fast amp (see the 200kHz square wave), and the drain resistors are quite high (compared to e.g. Aleph-X). Something to experiment with.
R5//R7 gives 50R 6W for the feedback, and half the inductance of a single 3W resistor.
The only remaning question for me is :
If I wish to go balanced, should I just use two of these or should I use complementary diff pairs for the first stage and Xed feedback ?
Hope there were no mistakes / mis-interpretations, and Nelson forgives me for saying openly my personal preferances.
Patrick
Old 15th April 2008, 07:41 PM   #98
lykkedk's Avatar
Patrick, i have build balanced F4's, and when looking at schm. i think it work's the same eg. 2x F5channels = 1balanced Mono, no need for diff pair or like.
Jesper.
Old 15th April 2008, 08:00 PM   #99
Of course it works.
The questions is what is better.
Patrick
Old 15th April 2008, 08:24 PM   #100
TimS is offline TimS  New Zealand
Default Simplified Balanced F5
A balanced F5 could be done like this
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2013 diyAudio
