#51 |
Thanks Nelson.
So heres my plan.Use a single down firing 8" woofer(similar to bottom section of the shadow) in each of the front corners.Unless having the dual woofer set up like the shadow in one corner is deemed to be better? The electonics will consist of 1)an input buffer for the Panasonic mic element. 2)a single pole 70hz hipass filter. 3)a single pole 100hz lowpass filter 4)invertor stage. 5)gain control 6)Chip amp. Should I proceed on this course? |
#52 |
Before I acually start does my plan outlined in the previous post seem plausable?
#53 | |
The one and only
placing it in a corner gets the most effect, as corners are where the resonance pressure builds up the most, and this way you hit two corners with one unit.
#54 |
Thanks Nelson ,the reply is much appreciated.
To clarify I may build 2 single woofer units and place them in different corners. |
| Active 3-ways with solen active loudspeaker module | soundemon | Multi-Way | 14 | 19th March 2009 11:17 AM |
| anybody acoustically treat their room with QRDs or sound absorbers? | thadman | Multi-Way | 2 | 19th July 2007 07:58 PM |
| Behringer DCX2496 I want to try active biamping using it as the active xover. | georgehifi | Digital Line Level | 3 | 15th August 2006 07:46 AM |
| Active bass absorbers | Pan | Pass Labs | 3 | 18th November 2003 09:34 PM |
| Page generated in 0.07074 seconds (77.53% PHP - 22.47% MySQL) with 11 queries |
