| Home | Forums | Articles | Links | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
We're saving for a new server - help us to serve you by Donating Today and become a friend with benefits!
Ads on/off / Custom Title / 2009 Tshirt / More PMs / Bigger Images / Advanced printing |
Thread Tools |
Hi Friends,
I want to use 30Volts DC single ended power supply instead of +15 0 -15 volts which is a split power supply. I will appreciate if soneone can suggest any kind of modifications needed in this circuit inroder to use with the single ended power power supply. thanks |
#2 |
The easiest solution is to use a resistive divider to create a virtual ground at +15V, then use the circuit as-is.
Grey |
#3 |
The one and only
That will work, but I like to run a capacitor between the virtual
ground and the "-" supply also. |
#4 |
Thanks Mr. Grey and MR.Nelson
perfect it's working |
#5 |
Nelson's idea is good. I'd go one further and put a cap between the + rail and the virtual ground.
Grey |
#6 |
I think you will also need some protection from turn on/off conditions being unfavorable to the input of your Op-amps. I overcome this with something like a 1k right at each input.
| Thread Tools | |
| power supply question.... too many Volts? | akimball442 | Tubes / Valves | 3 | 18th February 2007 05:12 PM |
| 16 volts 3A regulated power supply help | sunny | Power Supplies | 30 | 3rd November 2006 12:51 AM |
| Volts AC rating in power supply caps | rick57 | Tubes / Valves | 6 | 28th May 2006 01:59 AM |
| How to use a 220 Volt power supply at 12 Volts in the car? | Mr. Old School | Car Audio | 3 | 10th March 2006 01:11 AM |
| Negative volts and grounding in bench power supply | falcott | Parts | 10 | 26th October 2004 07:01 AM |
| Page generated in 0.16032910 seconds (70.32% PHP - 29.68% MySQL) with 11 queries |
