how to use 30 volts DC  instead of split power Supply
Old 2nd April 2008, 12:20 PM   #1
ali_moinuddin is offline ali_moinuddin  Indonesia
Default how to use 30 volts DC instead of split power Supply
Hi Friends,
I want to use 30Volts DC single ended power supply instead of +15 0 -15 volts which is a split power supply.
I will appreciate if soneone can suggest any kind of modifications needed in this circuit inroder to use with the single ended power power supply.
thanks
Old 2nd April 2008, 02:14 PM   #2
GRollins is offline GRollins  United States
The easiest solution is to use a resistive divider to create a virtual ground at +15V, then use the circuit as-is.
Grey
Old 2nd April 2008, 06:35 PM   #3
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
That will work, but I like to run a capacitor between the virtual
ground and the "-" supply also.
Old 2nd April 2008, 08:45 PM   #4
Thanks Mr. Grey and MR.Nelson
perfect it's working
Old 2nd April 2008, 09:01 PM   #5
Nelson's idea is good. I'd go one further and put a cap between the + rail and the virtual ground.
Grey
Old 2nd April 2008, 10:34 PM   #6
flg is offline flg  United States
flg's Avatar
I think you will also need some protection from turn on/off conditions being unfavorable to the input of your Op-amps. I overcome this with something like a 1k right at each input.
how to use 30 volts DC  instead of split power SupplyHide this!Advertise here!
Negative volts and grounding in bench power supply falcott Parts 11 29th April 2011 03:42 PM
power supply question.... too many Volts? akimball442 Tubes / Valves 3 18th February 2007 04:12 PM
16 volts 3A regulated power supply help sunny Power Supplies 30 2nd November 2006 11:51 PM
Volts AC rating in power supply caps rick57 Parts 6 28th May 2006 12:59 AM
How to use a 220 Volt power supply at 12 Volts in the car? Mr. Old School Car Audio 3 10th March 2006 12:11 AM
Copyright ©1999-2017 diyAudio
