diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Pass Labs (http://www.diyaudio.com/forums/pass-labs/)
-   -   Aleph 4 signal leads (http://www.diyaudio.com/forums/pass-labs/120562-aleph-4-signal-leads.html)
PixelPlay 1st April 2008 11:44 AM
Hi
I need some advice on the maximum length of the signal leads for a pair of Aleph 4's. I know that they should be as short as possible, however due to limited space I would like to know what would be the maximum length that would not effect the performance? What problems may arise if they were too long?
Thank you for your time
Cheers
Greg
PixelPlay 1st April 2008 12:46 PM
Just to clarify:
The signal leads from the main board to the fet boards.
cheers
Nelson Pass 1st April 2008 09:11 PM
Usually you can get away with a foot or so without problems.
GRollins 1st April 2008 11:08 PM
Just make sure the Gate stopper resistor (the 221 Ohm resistor in series with each output MOSFET's Gate) is on the far end, close to the output device.
Grey
PixelPlay 2nd April 2008 12:11 AM
Thank you both for your help
The 221 Ohm resistor in series with each output MOSFET's Gate is on the output boards next to the mosfets ( very close ). Will the length towards 10 inches degrade the sound?
Cheers
Greg
Babowana 2nd April 2008 03:02 AM
I consider the length as a part of interconnect line. I would try different lengths of interconnect lines to learn about the different sound. In general, I do not feel any sound difference when I tried different interconnect line lengths (0.5m-3m).
BFNY 5th April 2008 03:28 AM
sorry, perhaps I missed it due to the NP server crash. Could someone direct me to the F4 schematic? I am eXperimenting with a 1-10Mohm impedance converter for my FMMPX project. Tube tuners want a -wide- load.
Bob
GRollins 5th April 2008 03:46 AM
http://www.firstwatt.com/downloads.htm
Grey
BFNY 5th April 2008 05:38 AM
2 Attachment(s)
Grey;
Many thanks. Attached is the circuit I have been playing with to convert from tube tuners to a 50k ohm input impedance on the circuit I'm using for FMMPX mono to stereo conversion
Bob
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
