Hello ! I have a problem !
I'm building the Zen V4 and today, I work on the transfo wire.... The probleme is: -At the output of my transfo, I have 40 VAC at 60 Hz and I have "" 36 VDC "" at the output of my bridge ???? I suppose to have about 55VDC I realy don't understand, the bridge is well instaled and I try many bridge and the result is the same ! Maby because I take the mesure without the capasitor but I don't think that this is normal.... Please, I need some help, I don't understand wath is appening now |
#2 |
the filter caps have to be installed, otherwise you will be measuring a full rectified waveform (not DC). If you have a scope I suggest you take a look.
#3 |
Hi arold19!
You don't have a problem...conect a capacitor at the ouput of the bridge and everything will be fine! The capacitor will charge in the peakes of the waveforme and you will end up with your espected voltage! Cheers Jorge |
#4 |
OK Thank you, I will try it tomorow and I will give you some news...
Thank you !!! |
#5 |
Thank you ! All is OK !
But I have a little question ! It is normal that when I fuse the primarie of the transfo with a 1.5 Amp fuse, the fuse broke 1 time on 2 heaven if the transfo is connect only at the capacitor ?? On the shema of Nelson Pass, it is written, "slow blow" fuse, I don't know what this mean ! Thank you |
#6 |
Hi Arold19
The fuse blow with the surge of the charging of the capacitors...yes you need to use a slow blow fuse! It a fuse that need more time to blow ant take a surge...usualy it have sand inside. All you need is to go to your local component shop an ask politly a slow blow 1,5 Amp fuse!Cheers Jorge |
#7 |
Arold19: When I was building my first amp, I did the very same thing you did. I was very disappointed when the DC off the bridge was slightly lower than the voltage rating of the AC secondary. Then I hooked up my caps and everything was as expected! It saved me an embarassing call to the transformer manufacturer...
| heater connection problem | alexg | Tubes / Valves | 1 | 29th October 2008 02:30 PM |
| Wallin jig, sound card and connection problem | JacquesK | Multi-Way | 5 | 19th May 2008 09:48 PM |
| Connection problem? | avenged421 | Car Audio | 5 | 19th April 2007 10:04 AM |
| Help for a Output Transfo problem | jogas | Tubes / Valves | 4 | 25th May 2005 11:48 PM |
| Connection problem - turntable to Hi-Fi | MACTHEKNIFE | Analogue Source | 6 | 6th March 2004 10:31 PM |
| Page generated in 0.08169 seconds (87.00% PHP - 13.00% MySQL) with 10 queries |
