XLR shorting jumpers - Page 2 - diyAudio
Old 6th March 2003, 12:52 PM   #11
vossie is offline vossie  Israel
Pass Labs use gold plated jumpers that stick into the outside of the XLR jack. Don't know if they make them or buy them somewhere. This is quite simple devices and you could get off buying some good quality, thick wire (maybe you can get gold-plated if you try hard enough) and make them yerself!
I bet if you moan hard enough someone might even consider buying wire, have it goldplated and nip off a few pieces for you.
Vossie
The brave might not live forever but the cautious never live at all!
Old 5th August 2007, 06:09 PM   #12
fcel is offline fcel  United States
Just wondering, those U-Shaped Jumper Pin, has anybody locate a source to buy it? I just spend an hour searching the web but couldn't find anything.
Old 5th August 2007, 06:38 PM   #13
The one and only
Nelson Pass's Avatar
We have them made.
Old 5th August 2007, 07:07 PM   #14
Magura is offline Magura  Denmark
Magura's Avatar
There has to be something in the water.....
Just make an interconnect with an XLR in one end, and RCA in the other...and short minus to ground at the XLR...and presto! you got the whole shebang in one cable
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 31st January 2009, 02:36 PM   #15
I use a on-off switch to toggle between XLR and un-balanced input for my Aleph 5.
http://www.penguinlovers.net/audio/XLR_4.jpg
Old 1st February 2009, 12:47 AM   #16
The one and only
Default Re: XLR shorting jumpers
Originally posted by tortello
Does anybody knows if the shorting plugs, employed by some brands - among these Pass Labs - to connect the cold pin with the ground one in XLR female connectors, are custom made or can be bought?
They are custom. I should start selling them.
Originally posted by Lucas_G
I have often heard that the boz must sound very coloured, whereas the bls and the Aleph P must sound much more neutral.
Is that also your experience?
The box is much the same as the Aleph L, a single-stage, single-ended
design. It has more distortion than the SBOZ or Aleph P and the
character is 2nd harmonic, where the Aleph P is 3rd harmonic.
Most prefer the Aleph P circuit, but not all.
Old 4th February 2009, 01:30 AM   #17
Algar_emi's Avatar
I made my own jumper using piece of 14AWG solid copper wire. Plugs just perfectly into the XLR socket. Works great.
Old 4th February 2009, 07:16 AM   #18
Send a message via ICQ to AndreaFx Send a message via MSN to AndreaFx
Cardas Audio CGSP.
See Audiokit.......3 euro each.
But........I use a switch as tomchaoda
Old 4th February 2009, 07:42 AM   #19
Lucas_G is offline Lucas_G  Netherlands
Default Re: Re: XLR shorting jumpers
Thanks Nelson for commenting on this.
Usually 3rd harmonics are experienced as a bit agressiv sounding, but most people describe their Aleph_P not as such. Is distortion in the Aleph_P so low that it hides its 3rd harmonics in the sound picture?
How does the B1 fit into this range?
Lucas
pass labs x-5 XLR jumpers ROLIKOV Pass Labs 6 20th November 2014 09:31 AM
Switcher/Selector for jumpers mavallarino Digital Line Level 3 26th July 2009 10:42 PM
Switch for jumpers mavallarino Parts 0 13th June 2009 12:20 AM
Replacing circuit board jumpers tom1356 Digital Source 1 29th April 2007 01:10 AM
Copyright 1999-2017 diyAudio
