Pumpkin preamp - More Boring Making Thread - Page 43 - diyAudio
Closed Thread
Old 30th March 2008, 10:08 AM   #421
spavleski's Avatar
Send a message via Skype™ to spavleski
Old 30th March 2008, 10:15 AM   #422
spavleski's Avatar
@Zen, Pot problem with "Crrrr" during rotation has gone after setting Bias to ZERO.
T H A N K S !!!
Old 30th March 2008, 10:39 AM   #423
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
not likely "BIAS" .........
"offset" ..........more likely .........
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 30th March 2008, 10:43 AM   #424
spavleski's Avatar
Yes, "Biasing" the offset ;-)
Old 30th March 2008, 08:44 PM   #425
dviswa is offline dviswa  United States
Hi Guys,
Now that my plitron "Over Kill trafo" has pretty much turned into "kill trafo", I need to find other sources for a transformer.
Has anybody successfully used the Apex Jr Mercury Magnetics TA110-W? Which other trafos have you guys been using?
Thanks,
Dinesh
Old 30th March 2008, 08:59 PM   #426
Zen Mod's Avatar
Originally posted by dviswa
Hi Guys,
Thanks,
Dinesh
why not - if you use two of them , to have twice 40Vac
you can always ask AR2 which one from Apex he use
Old 30th March 2008, 09:56 PM   #427
zettelsm's Avatar
Default Apex Jr TA110-W transformer
Hi Guys,
Thanks,
Dinesh
I am going to use the MM TA110-Ws for my Pumpkin-Shunty AC power supply. Doing a quick hookup to check voltage, two MM TA110-Ws can be hooked up to supply a nominal 40V - 0 - 40V or 48V - 0 - 48V, the latter too much probably for all but the lowest of line voltages -- Japan perhaps @ 100VAC line.
The transformers appear to be good quality E-I core and should have no problem supplying the required current to a stereo pair of preamp-regulators. In typical DIY overkill fashion, I picked up 4 of the TA110-Ws so I can go dual-mono.
The price is certainly very right!
Steve Z
Old 31st March 2008, 02:52 AM   #428
Default Re: Apex Jr TA110-W transformer
you can always ask AR2 which one from Apex he use [/B]
Thanks, ZM. PM sent to AR2
Steve Z [/B]
Steve,
Thanks. The price surely is right. I was planning on ignoring the 48V taps and use the 40V. Have you tried putting any load on them? Connect a 100W lamp maybe and see how they might perform. I might consider using 4 as well if I have enough space in the cabinet.
Dinesh
Old 31st March 2008, 03:02 AM   #429
zettelsm's Avatar
Default Re: Re: Apex Jr TA110-W transformer
Steve,
Dinesh
Hi Dinesh,
I have not checked out the load regulation of the trafos yet, but maybe tomorrow night a work I might have time to do so. Looking at the physical size and with my plan to use two per channel, I figured they would be well within their current capabilities and voltage droop loaded would not be a problem.
I plan on having the transformers and rectifiers in a separate box and bring only DC up to the preamp enclosure.
Steve Z
Old 31st March 2008, 03:10 AM   #430
Default Re: Re: Re: Apex Jr TA110-W transformer
Please do.
Wow, 2 Box design huh? Worried about interference or simply no space in the cabinet? The rectifiers are on the Shunty board, just curios, what would you gain, by building a rectifier in the other box?
Closed Thread
Copyright 1999-2017 diyAudio
