Pumpkin preamp - More Boring Making Thread - Page 42 - diyAudio
Closed Thread
Old 27th March 2008, 02:15 PM   #411
Magura is offline Magura  Denmark
Magura's Avatar
The key word here is as far as I'm concerned "FUSES" as in NO fuses.
Get yourself a handful of fuses, and try again after measuring the secondary voltage, BEFORE connecting the trafo.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 27th March 2008, 03:44 PM   #412
dviswa is offline dviswa  United States
Originally posted by steenoe
Did you by accident connect the secondaries, wrong? It has happened before. Check the secondaries with your DMM (AC) to see if they are connected as they should be. It sounds like you could have two "hots" connected to one side of the psu.
Steen,
I had the tech drawing from Plitron, it is a little unlikely. But yes, I agree, I will check again tonight and make sure I did not mess it up.
No Fuses I meant, the fuses on the board after the bridge and CRC. What I was trying to do is to make sure I was getting right voltages from trafo and bridge. Everythingelse, Shunty and Pumpy were not yet in the circuit. I have a fuse on the primary, which also blew out.
Hehe, do I have a choice?
Old 27th March 2008, 04:16 PM   #413
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
@dviswa :
if you are using fusible resistors , sometimes they are more prone to burning than usual stuff ;
anyway - use 0W5 either carbon or MF with value of 2E2
I wrote that in Cook Book , in addendum ;
I have no these problems , because I use just 1mF caps in my Shunty , but sp300B was first who tell me for that problem ;
that's why I added that note .
regarding fuse in primary .........
be sure that secs are polarized/phased regularly , and that fuse isn't too dreky for xformer size.
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 28th March 2008, 04:40 PM   #414
Originally posted by Zen Mod
@dviswa :
ZM,
Sorry I did not see it. I will fix the values when I reorder.
Good to know that I am not the only one.
I verfied the connections and measured again. I am getting open loop 54-0-54 on the secondaries . Surely, way too high. I have requested the manufacturer to fix this, Let's see what comes of it. After that I have to order and replace all teh lytic caps.
Also noticed that my home supply is around 125V instead of the rated 110V
Old 29th March 2008, 04:58 PM   #415
spavleski's Avatar
Send a message via Skype™ to spavleski
what's up dudengineer ?
(I'm hardly keepin' my eyes open ......... )
Workie, workie
Old 29th March 2008, 11:00 PM   #416
steenoe is offline steenoe  Denmark
steenoe's Avatar
Originally posted by spavleski
Workie, workie
Me too The pumpkin is getting a new home and bigger heatsinks , the case is with "see through lid"! Who could resist with all them green led's in there? Not me....
Old 30th March 2008, 02:01 AM   #417
zettelsm's Avatar
Default Pumpkin volume control
So Mr. Steen, do I see potentiometers in place of the Twisted Pear stepped volume control and input-output boards?
Would you care to elaborate on the changes and effects on sound, if any? I would like to benefit from your experience and reasons for the changes. . .
Thanks!
Steve Z
Old 30th March 2008, 02:07 AM   #418
Zen Mod's Avatar
Default Re: Pumpkin volume control
Thanks!
Steve Z
naah
don't count too much on his xperience ........ on next pic you'll see flies instead of pot
(talking about ........ once I mounted watering can instead of TV antenna on the roof , naturally with antenna cable connected to it ........ just to tease my neighbors .......... they have strange look few days ............ )
Old 30th March 2008, 06:23 AM   #419
zettelsm's Avatar
Default Steenoe's Pumpkin revised
Looking closer I see he had done away with input and output connectors too. Very nice trick -- two less connectors in the signal path. In fact, there are no connectors or controls anywhere on the new box!
Steve Z
Old 30th March 2008, 11:07 AM   #420
spavleski's Avatar
Completed !!!! Working !!!!
Now, most probably, the doctors would have to come to "take off" the constant smile from my face
Closed Thread
Copyright 1999-2017 diyAudio
