Closed Thread
Old 2nd February 2008, 04:48 PM   #301
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
Originally posted by Manu
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; Mighty ZM's Bloggg;I'm dumb
Old 2nd February 2008, 06:57 PM   #302
Zen Mod's Avatar
me thinks that they're olde americanino Lewyt xformers , which truly yours personally butchered from olde americanino WWII xmiter ..... on junkyard ......... where else ?
one xmitter - one xformer
3K6:18K
something like this - from machmat pagines :
Old 4th February 2008, 06:41 PM   #303
Manu is offline Manu  Europe
Manu's Avatar
Nothing broken today...
Hehe.
But you sowed doubt in my mind about the method used to thermal coupling the Zistors.
Would Schrumpfschlauch/Heat-shrink tubing/Krimpkous (thats for frère Jacques) instead of tie-Wrap be a better solution?
Manu
Anxious
Old 4th February 2008, 06:47 PM   #304
Zen Mod's Avatar
Hehe.
Manu
Anxious
why not ?
same length/height as tie-wrap - leaving exposed as much you can of eeny weeny TO92
Old 5th February 2008, 04:24 AM   #305
Magura is offline Magura  Denmark
Magura's Avatar
Hehe.
Manu
Anxious
No, it would not offer any tension once just around 45C, cause it turns soft at that temperature.
Zip ties or metal is the way to go.
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 5th February 2008, 10:11 AM   #306
Zen Mod's Avatar
Originally posted by vitalstates
here ya go :
http://www.axminster.co.uk/pricing/I...rill-22285.htm
but mine is not as sexy as the one shown in the pic
Ed
what's point ?
in through hole you make or in bigger dia hole ,than you need ?
through hole is a must - in 90% of situations , and exact dia for tap is easy to find ;
trick is in steady , slow drilling , lubricating is a must ( WD40 is handy , even if I use some more esoteric stuff - and you don't wanna know that's in fact nothing else than goat fat).
tapping - again lubricating is must ;
half turn right , then half turn back ........
coffee is obligatory , too .......
and no hurry
sounds easy ?
Old 5th February 2008, 11:36 AM   #307
Manu's Avatar
Originally posted by Zen Mod
what's point ?
and no hurry
sounds easy ?
For tapping in soft material like Al, I now prefer to use Hand tapping tool as I ended having must less broken tap than with drilling machines. I found that, this way, it is so much easier to control.
Lubrification with common lamp-oil (cheap) but I am not a profi.
For drilling, the opposite. I prefer pillar drill (broken drill on ZenMods pic is the result of free hand drilling on kitchen table, smoking and drinking a beer at the same time)
Old 5th February 2008, 12:37 PM   #308
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
redrill the bottom of the hole with a broken drill, you'll have more clearance for the debris, which makes the threading easier.
(me made lots of 50 cents/hr for tapping big holes during child slavery years)
pssst: anyone in Ostricha(or other Birdy-ca) interested in sharing a switcher dump ?
Not so much,.......if it says "ZM" in the corner.
Old 5th February 2008, 04:35 PM   #309
For tapping I use a guide of some sort, usually a piece of wood with a tight hole for the tap.
The guide is clamped onto e.g. the heat sink.
Old 5th February 2008, 04:59 PM   #310
DaveM is offline DaveM  United States
DaveM's Avatar
For tapping aluminum there are some tricks. Using a pillar drill or drill press as I know them is certainly helpful. If you are specifically talking about drilling heatsinks, I have often had the problem of the drill location coming out the other side partially on a sink fin. This will cause the bit to bend away from the fin and snap.
I use WD-40 as a lubricant when I don't have magic tap aluminum at hand. That stuff works better than anything else I have tried. It reduces broken drills and taps considerably. So, the trick is to mark the hole location as needed and start the hole dry. This will allow you to accurately locate the drill point on the mark. Once there is a small divet started, add you lubricant and begin drilling. With a pillar drill and a small bit, be very careful not to apply too much pressure. So drill down a bit and then lift the bit up and out of the hole. What you want to see is the aluminum in the flutes of the bit spin free as the bit comes out of the hole or as you plunge back into the hole, the aluminum should ride up the flutes and fall away. If you see that the material in the flutes is not clearing, you should stop and use a pick to get it out. When you break a bit 90% of the time it is caused by the material loading in the flutes and binding in the hole. Don't allow the material to load up in the flutes. Depending on the depth of the hole, put a drop of oil in the hole midway through the hole. You can tell if you need more oil if the flutes are not ejecting the chips well.
Tapping follows the same rules. Keep the chips out of the hole and you shouldn't have an issue.
Closed Thread
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
