Pumpkin preamp - More Boring Making Thread
Closed Thread
Old 10th November 2007, 10:21 PM   #41
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
Originally posted by steenoe
Me? Ya talking to me?, I am right here Just received the package today and those boards are way to nice to destroy with any solder stuff In fact they are so nice that I doubt that I can part with the set that you are supposed to have I also doubt that you have a bigger pcb collection than mine, I always order 2 sets of boards, one for building, one for collecting I am not getting slow on the trigger, I just wanted (for once) to see how you guys would do on your own That is not goin' too well, to say the least..... He-he...
On another note, thanks a lot to the Dynamic Serbian duo for offering these finely made boards to us starving DIY'ers. They are in fact, magnificent work. Just superb
Steen
if you insist - jormajj found before me what numbers for heatsinks are adequate ,at usual vendors :
Fischer
SK81-50 SA
SK75-50
Austerlitz
KS100.3-50
KS32.1-50E
ya realy like them?
just don't loose eeny weeny parts
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa...© by Mighty ZM
Old 10th November 2007, 10:38 PM   #42
Zen Mod's Avatar
Not a chance
Me?, I will swap the 310 thingies with some Toshiba 2SK369V's.
Why?? Just because I have them
you'll have trouble with pinout
and lookout from highish input level
Old 13th November 2007, 06:47 PM   #43
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Let's hope the guys at that forum handle Germanium better you, yea Sheetness.
Me sez : "like MKIII", also shunt type, but not the same.
The MKIII also has regulators on the amp boards, like CTC deepthroat.
Shunty good enuf for me, 8 of them.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 17th November 2007, 11:19 AM   #44
lykkedk is offline lykkedk  Denmark
lykkedk's Avatar
Hi... And nice weekend to all here...
Official making thread... I allway's like looking at picture's, so here is one more from me.
I am making final assembling of complete . On picture both my newly 'designed' inputselector + toslink-switch (To switch between 2 digital sources) is to be seen. Right at picture is a dual +5vdc PSU (1 for toslink thing's, and the other for turning relay's on/off)
My inputselector is made completly foolproof (NO COMMENT HERE PLEASE ). One(Me) can switch between 3 RCA input's (sry. ZenMod for not making it complete balanced), and 1 balanced input.
The 3 RCA (unbalanced) input's, also closes the -in connection, on both sides of 4deck alps pot. When balanced in is choosen, the -in connection opens up for that signal too. This is controlled by a normal 4positions rotary selector.
Normally i will use balanced out, but also here i made a switch, which are going to be placed on back of to switch between balanced/unbalanced out.
Just diden't tried it yet... maybee tomorrow ... but have to go now ...
Jesper.
DCG3 Dual DCSTB, R2R DAC in build (2 ReflectorD's (+5VDC/+3.3VDC) + SSLV1.1 (+/-12VDC))
AlephJ Mimi! http://www.diyaudio.com/forums/pass-...mimi-mini.html
Old 18th November 2007, 06:59 AM   #45
Zen Mod's Avatar
Originally posted by lykkedk
Please stop all that O.T. guys... hehe let's get back into battle ...
Anyway, this might be a dumb quistion, but i just got a thought about shortning -out, when not in use, is it ok to short -out to gnd ? or should it just be left 'open' ???
Please bare with me!
Jesper.
short it
Old 18th November 2007, 07:59 AM   #46
lykkedk's Avatar
short it
Thank's man... Actually i just tried it.
If i feed with 2vac sine, then 30vac sine come's out unbalanced, with -out 'open'... with -out closed, it spitzz out 45vac sine... that's a big difference...
JUST don't understand why ??? but nevermind... it work's fine.
I make this unbal/bal selector, so that i got possibility to use with other amp's than my F4...
Jesper.
Old 18th November 2007, 11:22 AM   #47
Zen Mod's Avatar
Jesper.
it's easy to understand - you always need two points to establish any voltage difference ;
with one leg open , you have gnd somewhere, but not really where it need to be ;
when you ground one of outputs ( you know - you can choose which leg you'll ground ) you have established both points , needed for current flow......
be careful - using with F4 oriented gain setting - with other amps
Old 18th November 2007, 04:29 PM   #48
carpenter is offline carpenter  United States
Paper mache horn fabricator
carpenter's Avatar
So, the pumpkin does single-ended out. I thought it might, but forgot where I read, or forgot to ask.
Just remember to ground one of the outputs. Check.
If this is supposed to be an inverting amp, do I gound the negative out?
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 18th November 2007, 04:47 PM   #49
Zen Mod's Avatar
where is the fun if I tell you everything?
just imagine xformer instead of ; both prim and sec CT-ed .
Old 18th November 2007, 05:11 PM   #50
lykkedk's Avatar
Woow... ofcause ZenMod... easy to understand, i also know that about floating gnd, but didn't just think of it in this case. I don't know why, but sometimes it's difficult to me to understand thing's in other perspectives than the one's i used to work with...
This is a very good explanation ZenMod, thank you for that.
Jesper.
Closed Thread
Pumpkin preamp - More Boring Making ThreadHide this!Advertise here!
Copyright ©1999-2017 diyAudio
