#41 | |
The one and only
If I did, it is an error. |
#42 | |
The one and only
between like devices of different lot codes is better matched than Vgs. If you're going to get persnickety about it, you match the devices in the operating amplifier, warming it up, measuring and listening. A perfect DIY activity. |
#43 |
I would like to spend more time on device selection than I do currently but given my time constraints, it's either that or build circuits. I choose building circuits. For the time being I'm still using the simple one-shot Vgs match, although I do match at the intended bias current.
A couple of months ago I went back through a batch of devices I had matched at a lower current and redid the matching for a higher current. There was some shifting of places back and forth, but nothing too Earth shattering. This was pretty much as expected, but it did make some minor differences in which devices I pulled. I didn't do any deep studying on it, but off the cuff, I'd say that something like one in four devices, maybe one in five, were different from the ones I would have pulled if I'd just gone with the original matching order. The devices that were left out of the new groupings were still fairly close to the groups I pulled; I could have used them without fear. Just figured I'd gild the lily a bit. Grey |
#44 |
I would like to ask which metal is used to pot the transformer.
Is it to shield the output stage or front end? And ... why on the other hand Firstwatt amps for ex. obviously don't need such shieldings. Manu |
#45 | |
The one and only
reason is for low magnetic noise, mostly to avoid driving ground wiring. The FW amps have about 1/5 the transformer in them and at that size, stray field is not nearly as much a problem. |
#46 |
I have found that the shielding does lessen noise, but also that sound is better without shielding...seems trafos doesnt like metals, or it may be a case of disturbing the grounding...I have discouvered that sound improves when "lifting" the trafo from cabinet...and I have even found that the use of a brass bolt improves on sound...and decoupling the bolt from the cabinet is even better...I prefer wood fore my amps
#47 |
Thanks Mr. Pass.
manu |
#48 | |
You didn't Ian. |
#49 |
Mr. Pass, refering to XA.5 literature, is it output stage now something like "first produced Aleph"?
#50 | |
Peter |
| Pass XA30.5 in Stereophile, May 2009 | PMA | Pass Labs | 19 | 22nd June 2011 11:06 AM |
| diy XA30.5 | tf1216 | Pass Labs | 10 | 20th July 2009 08:20 PM |
| origigi XA30 question | Zen Mod | Pass Labs | 4 | 11th September 2006 10:01 AM |
| SI´s Son of T-Amp reviewed in 6moons | PauSim | Class D | 15 | 9th October 2005 10:45 PM |
| Page generated in 0.09516 seconds (88.34% PHP - 11.66% MySQL) with 10 queries |
