I think I have blown my left channel with my power cord (linking the power supply to the Pearl). I may have inverted ground and V+ or earth grounded one of the pin while the other having the supply. I can now only hear a low hum in the output. It appear that I have a short-circuit because the transformer is overheating and the voltage between the ground and the V+ of the Pearl board is 0. When I test the impedance between these two pins, I also get 0. This is obviously not the case for the other working channel. I have removed C1, C2, C3 & Q1 and still get a 0 ohm between Ground and V+. Should I continue removing parts and test for short-circuit or there are other alternative? Any other part could cause this? I don't have a scope unfortunately...Thanks
Imagination is more important than knowledge. knowledge is limited, imagination encircles the world. Albert Einstein FrankDIY's Audio Corner |
#2 |
Shoot.... I know how you feel, having had DIY circuits DOA.
If I were you I'd replace all actives and electrolytic caps. The alternative is that you understand the circuit enough to troubleshoot it and you have also a sig gen and scope. Sorry, that's probably not what you wanted to hear. The good news is Pearl is a great design and not at all finicky so if you can get it rebuilt you should be fine. |
#3 |
found the problem, it was the damn 5-pin XLR cable I bought on ebay. The pin-3 of the XLR connector was electrically connected to the connector itself. I was powering the pin-3 that was short-circuited to the ground. Next time I will make my own cable or use a DB25 like Pass Labs
#4 |
BTW :Nice projects on your homepage. Félicitation Manu |
| Creating 5.1 Multi Channel sound from 2 channel | jenkrich | Everything Else | 5 | 1st September 2009 07:29 AM |
| Pearl: one channel down :( | Buhl | Pass Labs | 9 | 20th April 2009 11:28 AM |
| UCD180 short circuited with bad Loudpseaker | pa | Class D | 2 | 4th November 2005 02:06 PM |
| Pearl Problem after R14 in one channel | Mikelo | Pass Labs | 10 | 2nd March 2005 12:39 PM |
| HELP! I Short circuited a IRF9610, now what? | Edwin Dorre | Pass Labs | 10 | 19th June 2002 08:25 AM |
| Page generated in 0.08360 seconds (69.65% PHP - 30.35% MySQL) with 11 queries |
