#11 |
The one and only
Certainly, but I wouldn't lose any sleep over it.
#12 |
I build Aleph3 and found the Matching MOSFET is some kind of difficult. And few kinds of method for VGS measurements.
1. Use a power resistor to measurement it individual with same current & temp. 2. Use an Aleph3 circuit with only one Pair of IRFP240. Also individually. 3. Measurements it on real Aleph3 circuit. Check VGS on site. Actually I do it step by step. Then, I can get closest VGS & Voltage over Source Resistor. I got 16 of IRFP240 & Use 12 of them for my stereo Aleph3. I set 0.4V over 0.49ohm resistor (2W, 2%). All of the effort returns by Music. I am very enjoying it now. I think in such simple circuitry, have to control the performance by components quality & lots of matching works. Also more current is better. |
#13 |
Kasra,
One channel running with 0.5V over each resistor and 0.6V in the other channel is fine by me. Yes, I suspect this is partialy a consequence of using the BC550C in one channel and a ZTX450 in the other. Their is a noticable difference in gain for both transistors, so it is very likely to have an effect on the DC setting of the current source circuit. I don't think this is a negative effect. Actually a little more quiescent current in the ALEPH is probably a benefit. I know this small diffence will not have significant sonic effect. So go ahead, and enjoy your ALEPH Regards |
| PS Problem: How do I Reduce Voltage? | slor | Tubes / Valves | 7 | 27th April 2008 03:18 PM |
| voltage problem in 400watt amp | jojo_tennis | Solid State | 5 | 7th September 2005 03:33 AM |
| Voltage problem | sith | Tubes / Valves | 10 | 7th January 2005 12:20 PM |
| BOSOZ, PS voltage problem or not? | PsykoK | Pass Labs | 3 | 20th December 2002 08:12 AM |
| Aleph3 problem | rtirion | Pass Labs | 30 | 1st April 2002 09:56 PM |
