Aleph 30 going on..
Aleph 30 going on..
Old 26th February 2003, 05:35 PM   #1
Andypairo is offline Andypairo  Italy
Andypairo's Avatar
Thumbs up Aleph 30 going on..
I am currently idle-testing my amp with no load and no signal attached.
Power supply comes from a 2x22 Vac transformer (500 VA), primary capacitors (20 mF per rail), then a R-C for each channel (and rail) (165 mOhm - 30 mF).
Both rails are at about 30V dc, which is quite high for a Aleph 30 but since my heatsinks are big enough I don't care.
After a hour the thermistor I use for inrush protection settled at about 72 °C, while the heatsinks are slightly different but at least 20 degrees below.
I noticed that the "signal" mosfets get quite hot: is a small heatsink mandatory or they can be avoided?
for now.. that's all folks!
Cheers
Andrea
Old 26th February 2003, 08:34 PM   #2
Mad_K is offline Mad_K  Norway
Mad_K's Avatar
Default Re: Aleph 30 going on..
If you run normal bias (5V acoss R11) on them, they can be avoided. (I don't use them).
Mads K
Old 4th April 2003, 12:00 PM   #3
Andypairo's Avatar
Talking At last.. it is (almost) finished!!
Here are some photos of this little monster.. upper and back plate are made of sanded aluminium, the light from the pushbutton is actually blue (even if it doesn't seem...)
Old 4th April 2003, 12:02 PM   #4
Andypairo's Avatar
Next one
Old 4th April 2003, 12:03 PM   #5
Andypairo's Avatar
another.. closeup of the rear panel
Old 4th April 2003, 12:04 PM   #6
Andypairo's Avatar
inside view..
Old 4th April 2003, 12:05 PM   #7
Andypairo's Avatar
a photo was supposed to be in the previous message...
Old 4th April 2003, 12:07 PM   #8
Andypairo's Avatar
pant..puff... the last one!
Old 4th April 2003, 02:39 PM   #9
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
Phat!
nice case work
way to represent...
keep keepin' it real
m., out
Old 26th April 2003, 01:20 AM   #10
relder is offline relder  United States
relder's Avatar
Send a message via Yahoo to relder
How did you cut the slots in the top/back?
Aleph 30 going on..Hide this!Advertise here!
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 24 14th May 2017 11:03 AM
Aleph (Single Ended) + Larvadin (no Memory Distortion) = Ultimate Aleph? tiefbassuebertr Pass Labs 19 25th January 2014 02:15 AM
Mini Aleph Board & Aleph 2 Parts List gpsmithii Pass Labs 3 16th January 2010 03:58 AM
First version Aleph 0 (Null, ZERO, O, Os, 0s) versus later Aleph versions tiefbassuebertr Pass Labs 0 6th August 2009 11:11 AM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Copyright ©1999-2017 diyAudio
