I am wondering what type of enclosure is suggested for Pearl. I looked at Hammond cataloque (aluminum boxes) but couldn't find anything suitable. Any suggestions? Second, can I increase value of the ps capacitors without compromising anything (or much). I am thinking of using 22000uF instead of suggested 10000uF in the power supply (fig 4 in the manual). Thanks Boban |
#2 |
Hi Boban,
I'm in Toronto as well, and have built a lot of electronics and speakers. I'd love to hear the Pearl (thinking of building it or the Ono). I can offer you some help, seems like this is the first time you've built something, and maybe then you'd let me use your Pearl in my system to test it? What exactly did not work with the Hammond enclosures? I can suggest some other places to look as well. Cheers, Ron |
#3 |
Problem with Hammond is that I could't find enclosure with the dimensions I like. The ideal (for me) would be something like 11x10x3.
Regards Boban |
#4 |
Check at Supremetronics, on Queen St. W. just east of Active Surplus. They have different size enclosures, one might fit. The other place to check is on Victoria Park, across from Sayal, near Electrosonic. I can't remember the name, but if you look for Sayal on Vic Park just south of Steeles, and then cross the street to the west side and go north about a block, there's a strip mall, there's a parts and computer store that carries enclosures.
Ron |
#5 |
Hammond aluminum enclosure, 12x10x2", part no. 1444-29 and bottom plate 1434-29. If you don't need the height, this could work. The tallest thing is likely your tranformer, maybe the ps caps, they should fit. The caps can go on their sides if need be.
Ron |
#6 |
Yes, you are correct. Caps are problem and that's why I am looking for something taller than 2 inch. Will check the places you've recommended.
Boban |
#7 |
Go for 3" depth, you'll need it with the PCB standoffs and the electrolytic caps.
I used a Hammond 17x10x3 chassis (if I remember right). Worked out fine, because I recently got a new MC cartridge, and there was room left over in the chassis for the step-up transformers so I didn't have to add extra RCA connections to the signal path. P.S. I built an outboard power supply, in a cheap Radio Shack enclosure, so I didn't have to fit PS transformers inside the main chassis. If you're building the Pearl in one enclosure, your height requirements might change. |
#8 |
Thx Saurav,
what about the umbilical cord? |
#9 |
I think I tried multiple options, and then ended up with some multi-conductor cord I bought somewhere. I know that thicker gauge would be better for the power and ground lines, but it seems to work fine, and the hum levels are acceptable in my system, so I haven't bothered with trying to improve it. I bought male/female DIN connectors and soldered 4 of the conductor wires in the cable to 4 pins on the DIN connector. I think my cable is shielded, and off the top of my head I don't remember if I connected the shield at one end or both ends. I was battling serious RFI problems at one point (after I rewired my tonearm), so I was trying everything I could think of.
#10 |
I built a combination of the pearl phono section and the Aleph L as my line preamp. The preamp sounds great! I used enclosures from Par Metals in NJ (one for the power supply and one for the electronics). Par has some nice 19" rack mount enclosures at very good prices. I do not know if they export to the Great White North, however (although I shouldn't talk as it is pretty snow-covered here in Connecticut).
-Paul http://www.par-metal.com/ |
| Aleph 1.7 : power supply enclosure | ndhennin | Pass Labs | 3 | 25th July 2006 03:34 AM |
| Power supply for Pearl phono | mattjk | Pass Labs | 6 | 11th February 2005 08:25 PM |
| Pearl Phono power supply | Gregorio | Pass Labs | 1 | 13th October 2004 06:12 PM |
| Power Supply for Pearl | dkimble | Pass Labs | 6 | 16th March 2004 05:57 PM |
| Beginner questions about Pearl power supply | Saurav | Pass Labs | 3 | 26th September 2002 04:18 PM |
| Page generated in 0.09448 seconds (80.24% PHP - 19.76% MySQL) with 11 queries |
