Old 25th February 2003, 02:27 PM   #1
Default CL 60 thermistor For Aleph 2
Hello for all
I have a problem on the temperature of the thermistor CL 60.
when I light my block Aleph 2, I have a rise in immediately temperature of thermistor 1.
which is the problem?
or perhaps that it is normal.
thank for anwser.
stay zen
Old 25th February 2003, 02:30 PM   #2
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
This is how it works. When temp rises the resistance goes down and it should be like that.
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 25th February 2003, 03:47 PM   #3
thank you that reassures me.
stay zen
Old 25th February 2003, 04:17 PM   #4
joensd is offline joensd  Germany
Hi jeclk,
where did you get the CL60?
I haven´t found any distributor so far here in Europe
though there must be one.
TIA
Jens
Old 25th February 2003, 07:48 PM   #5
Default Adress in Europe
Hello Jens,
it's a company which is in France I give you the reference or the code CL 60.
code designation
"TEXCL60" THERMISTANCE CL 60
if you want of the assistance to communicate with society, say me, I say will contact them.
http://www.radialex.fr
phone: 33 (0)4 72 35 31 72.
if you have a good address for the heatsinks, say it me.
regards
jeclk
stay zen
Old 25th February 2003, 07:50 PM   #6
stay zen
Old 25th February 2003, 09:11 PM   #7
nobody special's Avatar
Default yes, and no...
That is the case if it is being used as an inrush suppressor. If it is being used to isolate the grounds, as in some of the zen projects (or maybe A75?), you may have a problem!
Old 25th February 2003, 09:33 PM   #8
uli is offline uli  Austria
Originally posted by joensd
Hi jeclk,
TIA
Jens
Hi Jens,
kuck mal www.rs-components.de
In Ö gibts Vergleichstypen unter Passive Bauelemente-
Entstörbauteile- Einschaltstromspitzenbegrenzer
Ich verwende die 3A / 15Ohm, "S237/15/M"
Part# 216-1393
da CL60 = 5A / 10 Ohm
aber nur 110V und doppelter Strom
Funktionieren einwandfrei
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 25th February 2003, 09:58 PM   #9
Default Re: yes, and no...
That's a good point and I was talkng about inrush supressing.
www.audiosector.com
Old 25th February 2003, 11:52 PM   #10
grataku is offline grataku  United States
Right off the top of my head...there is also something to be said about using a single cl-60 to do inrush protection on an aleph 2. I guess in Europe they have higher mains but I would check to make sure that the temp is within the rating.
Thermistor help luvtheoldschool Parts 5 4th February 2008 12:56 PM
thermistor larryg Solid State 15 21st October 2004 03:40 PM
Thermistor for Aleph 3 (Inrush current) Miles Teg Pass Labs 18 21st October 2002 08:01 PM
aleph 2-thermistor coat cracked marijan Pass Labs 8 2nd September 2002 07:29 PM
Thermistor for Aleph Miles Teg Pass Labs 2 23rd January 2002 04:33 AM
Page generated in 0.09724 seconds (81.57% PHP - 18.43% MySQL) with 10 queries
