My own Pumpkin preamp - Construction
Old 22nd January 2008, 02:27 AM   #1
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Default My own Pumpkin preamp - Construction
I'n my spare time from the Maxon GB 2007 (and night and weekend ), I started to work on some enclosure to mount the Pumpkin preamp. I bought a set of PCB a few weeks ago. I'm collecting the parts for now.
The preamp will have a separate supply module that will contains a custom Plitron surplus transformer that I got directly from Plitron. It is hugely overkill. It has also some extra secondaries, one of which I will use to supply the preamp digital section and input selection boards, more on that later.
This is the transfo enclosure. It is made of laminated dried maple on the outside. The inside is a complete aluminium enclosure. The top has some spare space reserved to receive a plate of black tinted glass or black plexiglass for a nice finish all around.
Old 22nd January 2008, 02:33 AM   #2
Algar_emi's Avatar
I'm still working on the preamp enclosure. It is built the same way but has 1/4 inch alu inside side panel and a center 1/4 inch alu spine for extra case rigidity. The central spine will also insulate each channel from each other.
I'm planning to use my Placette attenuator kit as volume control. A set of external connectors will allow the Placette to be used by itself if I choose to. The Placette I have is fully balanced, as needed by the Pumpkin. The kit will also allow volume remote control. The processor and LCD Placette control PCB will be mounted on the front, inside the wood. The back will be closed by an alu plate for shielding. The processor and relay will use a separate digital supply. This supply has a built-in EMI filter.
The source selection will be done using a selector switch and back mounted relays PCB, close to the inputs conenctors.
The preamp back is made of brushed, anodized panel that I recycled from an other enclosure. The round notch on the back will receive the input power connector.
Old 22nd January 2008, 04:55 PM   #3
jupiterjune is offline jupiterjune  United States
Well, if you insist on using such thin material, it is the least you can do
Seriously--beautiful work--completely overdone as any good DIY project should be.
JJ
Old 22nd January 2008, 09:15 PM   #4
Zen Mod is offline Zen Mod  Serbia
Official Court Jester
Zen Mod's Avatar
like always from AE - fugly!
my Papa is smarter than your Nelson !
clean thread; Cook Book;PSM LS Cook Book;Baby DiyA ;Mighty ZM's Bloggg;Papatreasure;Papa... by Mighty ZM
Old 23rd January 2008, 12:02 AM   #5
Algar_emi's Avatar
As some said on this forum, what is the point in building something simple and cheap. We may as well buy some noise box from Circuit City and be done with it. Maybe half of the price of the very high end stuff is casing and cosmetic anyway.
Part of the fun is to try to build things differently and reach for the top.
I guest the Pumpkin with its sophisticated supply is worth nothing less
Old 23rd January 2008, 12:18 AM   #6
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
Ooooooooooh.
Shiny.
Old 23rd January 2008, 12:46 AM   #7
Algar_emi's Avatar
Indeed. And great thing about covering the aluminium with wood, is that I'm better at finishing wood than alu .
Old 6th February 2008, 04:50 AM   #8
wirewiggler is offline wirewiggler  United States
I agree, I have limited metal machining tools, however wood is relative easy to machine. I like to refer to mine as the Pass woodies. I was reviewing your 2.2 BOM as mentioned R20,23,24,25 on Pumpkin need updating. On shunty D6,6a,7,7a leads are to big for holes, C19a),C4(a) C12(a) need to have 15mm spacing. C17,C17a,C18,C18a, Is Wima ok to use in place of ceramic (plead ignorance on my part)? I appreciate your work on the BOM Have you had any luck with heatsinks? I looked in all my catalogs and am unable to locate the ones used on Q1,Q1a. I will make a trip to Apex JR soon to see if I can find something suitable for the larger heat sinks, if something looks usable I can pick some up for you.
Bill
Old 6th February 2008, 09:27 PM   #9
moe29 is offline moe29  United States
moe29's Avatar
Send a message via AIM to moe29 Send a message via Yahoo to moe29
Shiny.
Firefly fan?
can't wait to see the finished product
Old 7th February 2008, 03:26 AM   #10
located heat sinks:
Futurlec has the little ones part # TO218S049B $.90 - http://www.futurlec.com/Heatsinks/TO218S049B.shtml and the Larger ones Surplus sales of Nebraska (HSK) HS-DMC501 $4.50 - http://www.surplussales.com/Heatsinks/HeatSink1.html . Will have to file the fins a little bit mabe 1/16, and they may overhang the sides a tad but close enough for me. Oh yea and Apex Jr has a Transformer 15-0042 92 VCT 250 VA (a little over kill ) $25.00 http://www.apexjr.com/miscellaneous.html#Transformers .
Bill
My own Pumpkin preamp - ConstructionHide this!Advertise here!
Copyright ©1999-2017 diyAudio
