Old 24th February 2003, 11:42 AM   #1
vossie is offline vossie  Israel
Default Aleph 5 resistors
I have noticed that different wattage values are promoted for the Aleph 5 1 Ohm and 0.47 Ohm resistors. I have seen 6 W and 10 W spesifications.
Problem with the 10 W resistors is size. Struggle to find good ones here in CT.
Is it OK if I use 6W ones? Most of the pics of finished pcbs show small (looks like 5W ones) resistors. Where can I find these (green color)?
Thanks,
Vossie
The brave might not live forever but the cautious never live at all!
Old 24th February 2003, 12:08 PM   #2
rwagter's Avatar
I have used 3W panasonics just as in the standard alephs so 6W is more then enough
Old 25th February 2003, 05:31 AM   #3
Tomasz Rodak's Avatar
Hi !!!
I think you can try resistors Mills MRA-12 (12 W) from
www.partsconnexion.com, they can send you them to RSA. Resistors are big but it is not a problem considering their high quality (3,56 USD/item, 6 USD p&p).
regards
Tomek
Old 25th February 2003, 05:40 AM   #4
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
No reason to go with 12W resistors, Mills 5W are enough and they are about the size of 3W Panasonic used by Pass Labs. Panasonics can be obtained from Digi-Key.
I thought you won that Aleph 30. Why don't you look inside?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 25th February 2003, 06:42 AM   #5
cowanrg is offline cowanrg  United States
cowanrg's Avatar
Send a message via AIM to cowanrg
there is a local surplus place that carries NOTHING of much quality except for tons of mills resistors, at very nice prices. let me know if you are interested in anything, im going there tomorrow and can at least scout out prices for you.
Old 25th February 2003, 09:09 AM   #6
I'm sorry, I mixed up everything. Of course there is no need to use 12 W resistors in Aleph 2, and with regard to Aleph 30 which Peter Danie mentioned above I like to admit that I have been building it and I have no one workable at the moment. I will attach pictures in the near future when it is ready.
regards
Tom
Old 25th February 2003, 06:06 PM   #7
Hey boys, we're talking Aleph 5, not 30 or 2 here. You can actually calculate the wattage (P=VII). As the Aleph 5 has 34 rail voltages as opposed to 25 of the 30 I did not bother to calculate and also not to consider they can be the same - just tried to take some advice wich seemed a bit too inconsistant. Have decided that the 3 Watters will be OK
Thanks for yer help,
Vossie
Oh, yes Peter, it's beautifull inside ...
Old 26th February 2003, 02:28 AM   #8
Coulomb is offline Coulomb  England
Coulomb's Avatar
Does the fact that the Panasonics are 5% Tolerance affect the sound at all? for instance a .47 Ohm 5% resistor can drop to .45R or surge to .4935R?
Where a 1% would only drift by .0047R, hardly noticeable.
Anthony
Old 26th February 2003, 04:24 AM   #9
Most important is how they are matched together. That's why I buy a 100 and measure.
www.audiosector.com
Old 26th February 2003, 09:19 AM   #10
Why then not just buy Caddocks or something of that quality?
btw I understood measuring low values wasn't easy?
Is that all there is?
5 Watt Resistors on Aleph 4 and Holco Resistors nicharis Pass Labs 16 8th February 2012 07:50 AM
Aleph x resistors values elviukai Pass Labs 15 29th May 2006 06:56 PM
Resistors in Aleph-X Hastur Pass Labs 8 7th February 2006 10:18 AM
Resistors in Aleph 2 diyman Pass Labs 1 4th May 2003 06:57 PM
Aleph 2 resistors ? jeclk Pass Labs 0 23rd October 2002 08:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
