Old 24th February 2003, 04:21 AM   #1
Default Bridge Rectifier Ground loop fix (seen in Zenv4)
Fellow DIY'ers,
My apologies in advance if this is just another boring grounding question:
I'm building two mono zenv4s, and I'm not sure how to isolate their grounds. I don't really want to shell out $12 for 2 200V 35A bridges, so I'm wondering if there's another (cheaper) solution to isolate the two amps from each other (since I can't use Nelson's bridge trick, cause the channels are in separate cases).
Could I just use 2 diodes (per channel) connected to earth ground (like half a bridge)? And, if so, do they need to be as gigantic as the bridge? I've got a bunch of 400V 1A 1N4004's lying around.
Thanks,
Chris McGraw
Old 24th February 2003, 10:37 AM   #2
uli is offline uli  Austria
Default cl60
take a cl60 instead (like in the Alephs)
Uli
'Jazz is not dead, it just smells funny' F.Zappa
Old 24th February 2003, 03:32 PM   #3
dwjj's Avatar
What you need to worry about are fault currents. Think if the primary and secondary shorted in the transformer, or some other fail to induce high voltage/current on the ground connection. You've got to make sure that the ground connection can survive until the fuse blows, until your circuit breaker blows, anything so that your case doesn't become energized.
Using 2 diodes in parallel from the 35A bridge can support a lot of current. That's why he did it that way. I don't think 1A is a safe substitute. Might work to parallel 30 or 50 together?
It's cheaper than a movie, and there's free coffee.
Old 24th February 2003, 05:47 PM   #4
joensd is offline joensd  Germany
Default Re: Bridge Rectifier Ground loop fix (seen in Zenv4)
Originally posted by cmcgraw
Fellow DIY'ers,
Thanks,
Chris McGraw
I canŽt give you good advice about alternatives but 12$ for a 200V/35A rectifier seem quite high.
For that price IŽd get 7 units at my supplier.
Try to source it elsewhere.
Jens
Bridge rectifier vs Full wave rectifier hilbert_mostert Tubes / Valves 4 28th April 2009 08:26 PM
hum,ground loop,earth loop problem with your answers please frank2395 Pass Labs 2 17th May 2005 06:46 PM
Isolating Bridge Rectifier Ground for Zen v4 Super_BQ Pass Labs 1 3rd February 2004 05:45 PM
does connecting mains ground with circuit ground create a ground loop? jarthel Everything Else 0 25th June 2003 12:55 PM
Page generated in 0.09068 seconds (75.46% PHP - 24.54% MySQL) with 10 queries
