How much heat sink is necessary?
Old 23rd February 2003, 04:21 AM   #11
ultrachrome is offline ultrachrome  United States
Can you recommend a blade for both? I have the 12" dewalt and I tried using a high speed metal blade (composite) I had lying around. It wears too quickly to cut my heat sinks so that the motor housing touches the material before it's all the way through.
I thought about just renting a 14" chop saw from Home Depot which should have no trouble even with blade wear.
Thanks.
Old 23rd February 2003, 05:23 AM   #12
Brian Donaldson is offline Brian Donaldson  United States
Brian Donaldson's Avatar
Default Blade
12 inch chop saw is compound miter, not abrasive saw.
I use Dewalt # DW3229 80 Tooth triple chip -5 deg rake.
They retail for about $85.00. The anodizing is very hard, so try to push through it quickly or it will dull the carbide quickly. But don't be too agressive or it may bend the fins and bind. That would be bad in many regards!
How much heat sink is necessary?Hide this!Advertise here!
heat sink for UCD700? pburke Class D 68 7th July 2006 04:40 AM
LM3875 heat sink help. CJ Paul Chip Amps 4 10th March 2006 08:14 PM
Heat Sink Question darth_audio Car Audio 2 14th October 2005 04:47 PM
DH-500 heat sink assembly Dick West Swap Meet 2 13th April 2005 03:51 AM
1 ton of heat sink on ebay Da5id4Vz The Lounge 5 24th October 2003 02:02 AM
