#31 |
I suppose I should add that I assume that Nelson's patent applies to my circuit as well, in those territories where the patent has been granted.
It was certainly designed with Nelson's ideas very firmly in mind, as the simplest discrete circuit I could think of that gave DC accuracy and the supersymmetry principle. |
#32 |
Here is the circuit as I am laying it out now.
It has short circuit and SOA protection. It is thermally stable thanks to the CFP output. The distortion should be very very very low. ![]() The PDF is of the simulation, reference designators and such are not finalized. It is a simulation of the circuit in I/V mode with filter caps for a Fc of about 200khz. The circuit as shown would work with PCm1794A and output 2VRMS peak output. Cheers! Russ
Less pulp more juice Twisted Pear Audio. |
#33 |
here are the simulated THD number into the 300R/300pf load:
The first is the balanced THD, The second is the THD of a single output to GND. Heightened Def Con from 0.000256019 to 0.000256019 Fourier components of V(out+,out-) DC component:8.29446e-010 Harmonic Frequency Fourier Normalized Phase Normalized Number [Hz] Component Component [degree] Phase [deg] 1 2.000e+04 2.770e+00 1.000e+00 -5.68° 0.00° 2 4.000e+04 7.463e-10 2.694e-10 -20.80° -15.12° 3 6.000e+04 5.798e-08 2.093e-08 69.54° 75.23° 4 8.000e+04 7.130e-10 2.574e-10 -126.70° -121.01° 5 1.000e+05 1.230e-08 4.440e-09 149.26° 154.95° 6 1.200e+05 1.214e-09 4.382e-10 -63.77° -58.09° 7 1.400e+05 8.478e-09 3.061e-09 -50.92° -45.24° 8 1.600e+05 1.409e-09 5.087e-10 50.66° 56.34° 9 1.800e+05 3.645e-09 1.316e-09 -29.03° -23.35° Total Harmonic Distortion: 0.000002% Fourier components of V(out+) DC component:-0.000220695 Harmonic Frequency Fourier Normalized Phase Normalized Number [Hz] Component Component [degree] Phase [deg] 1 2.000e+04 1.385e+00 1.000e+00 -5.68° 0.00° 2 4.000e+04 6.406e-07 4.626e-07 -15.68° -9.99° 3 6.000e+04 2.908e-08 2.100e-08 70.81° 76.49° 4 8.000e+04 1.410e-09 1.018e-09 139.62° 145.31° 5 1.000e+05 5.837e-09 4.215e-09 152.53° 158.21° 6 1.200e+05 1.175e-09 8.487e-10 -79.13° -73.44° 7 1.400e+05 4.244e-09 3.064e-09 -43.23° -37.55° 8 1.600e+05 1.138e-09 8.217e-10 14.40° 20.09° 9 1.800e+05 1.647e-09 1.190e-09 -40.27° -34.58° Total Harmonic Distortion: 0.000046%
#34 |
20 khz, same load
Green trace is balanced output. Blue is SE.
#35 |
Are these discrete balanced I/V (and LPF) stages going to be available soon ?
From your trials of these : are they worth it over THS4131 opamps IVY stages ? I will place an order of COD modules and wonder if discrete balanced I/V stage is coming. thanks in advance |
#36 | |
Hello, Yes they are coming at some point. We just have a lot to do right now. Measurement wise I doubt it will be much if any better than the THS4131, it may actually not be quite as good, but it will have more load current capacity, and it is discrete which will make some people happy. ![]() I will have one measured and report when the project is finished. Cheers! Russ
#37 |
Hi Russ, very nice indeed...any progress on this one ?
#38 |
Thanks Blitz,
I am testing a proof of concept output stage which I plan on applying to this circuit as well. If that goes well then I will proceed with this amplifier. Thanks for your interest. ![]() Cheers! Russ
| 990 discrete opamp | udip | Solid State | 18 | 12th February 2009 11:00 PM |
| My discrete opamp | udip | Solid State | 51 | 8th August 2006 07:33 AM |
| How Super-Symmetric can SuSy be? | Netlist | Pass Labs | 24 | 11th December 2003 10:27 PM |
| Audio Crafters Guild "Super Symmetric Power Supply" | raincheck | Digital Source | 16 | 22nd April 2002 08:06 AM |
