Old 15th December 2007, 09:10 PM   #1
Paper mache horn fabricator
carpenter's Avatar
Default JfetBOZ mods
Moderators, please feel free to relocate this as you see fit.
I'm thrilled with my JfetBOZ. It's currently acting as a line-stage in front of my F4.
Of course, Nelson has given us many examples of how to modify, and (hopefully) improve a circuit. I'm going to breadboard this CCS to my JfetBOZ. I thought I'd share my idea; perhaps someone out there has thoughts or suggestions they'd like to put forth.
I enjoy audio so much that I constructed a web site. I share my ideas at: www.inlowsound.com
Old 15th December 2007, 09:38 PM   #2
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
it's easier , better because of bigger dynamic resistance (maybe even better noise -wise) to implement other sort of CCS .......... say - CCS from toob boyz P10, Geek and others , or two bjt ccs which you can see in Bab and Pumpy .
besides that - if you want to use CCS there - you'll either lift source of jfet too high , or bottom CCS .......... same thing called with different names ......
point is that jfet need adequate voltage between S and G for defined current ; CCS need some voltage to breath , and that's certainly not so small voltage - which Jfet need between S and G .........
so - conclusion - Jfet gate stays at gnd potential , but tail of CCS must go lower ...............on negative voltage
look at ccswhatever bosoz , cascoded or not and than say what you saw
EDIT:
well - I didn't even mention gain issue .........etc
maybe is better to relocate CCS up , and then - choosing adequate source degeneration resistor ........ set desired gain
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 15th December 2007, 10:21 PM   #3
carpenter's Avatar
Looks like I have more homework.
Old 15th December 2007, 10:34 PM   #4
Zen Mod's Avatar
go to last third of Pumpy developing/amusing/musing/maki'funofit thread and look for schematic of thing, with voltage values in it ;
I drew that for crazy danske Lykkkkkkk , one of many times when he was in trouble .
there you can see few important things ;
or you can try Papa's cascode pdf
or you can go to Borbely's and look for his papers regarding line stages ...... "...frontiers" stuff .
are you familiar with toobz?
Old 15th December 2007, 10:44 PM   #5
mpmarino's Avatar
more legs?
Carpenter, Is your intention to use a jfetBOZ variation as your preamp for your F4?
Crazy Yankee.
Old 15th December 2007, 11:41 PM   #6
carpenter's Avatar
Originally posted by mpmarino
more legs?
I need it more as a line/gain stage. I have a receiver for home theater/Dolby and such. The Jfet BOZ is an interface.
Old 16th December 2007, 12:28 AM   #7
I haven't yet come to the Jfet Boz. Too many other projects, but getting closer.
Anyway in the DIY opamp paper Nelson Pass show a simple bjt ccs.
I put it in the Jfet Boz circuit instead of the source resistor. The sims give the same voltages and currents as with the resistor.
Old 16th December 2007, 01:40 AM   #8
mpmarino's Avatar
Cool .. I'm sure you'll make it work nicely
Crazy Yankee.
Old 16th December 2007, 01:59 AM   #9
Formerly "jh6you". R.I.P.
Babowana's Avatar
If you replace the source resistor with CCS,
the Jfet will not work as a voltage gain device.
Old 16th December 2007, 02:44 AM   #10
flg is offline flg  United States
flg's Avatar
Carpenter, I'm not sure what your trying to do But, I've been building up the thing below. It's nothing new but it has the capability of enough voltage swing to drive an F4... Or, provide line level voltage swings with great headroom
Page generated in 0.09989 seconds (82.76% PHP - 17.24% MySQL) with 11 queries
