ZEN V4 without feedback loop
Old 19th February 2003, 07:56 PM   #1
Selfmade is offline Selfmade  Germany
Default ZEN V4 without feedback loop
I have build a ZEN V4, and I want to eliminate the feedback loop from the output to the input.
Are there any negativ aspects?
Is there an improvement in sound?
regards
Günter
Old 19th February 2003, 08:34 PM   #2
Nelson Pass is offline Nelson Pass  United States
The one and only
Nelson Pass's Avatar
I suggest that you want to retain the "internal" high impedance loop from the output device's Drain to its Gate, as this sets the DC value of the output, otherwise feel free. Be prepared for a lot of gain, tho.
Old 19th February 2003, 08:41 PM   #3
thank´s for the answer Mr. Pass.
I mean the feedback loop from the output after the caps to the gate of the ZVP3310 with resister 221K and the capacitor 5pF.
regards
Günter
Old 19th February 2003, 08:45 PM   #4
The one and only
Right. Just remove it and ground the 47K input resistor. Replace
them with an input divider, formed by about 5 K from input to the Gate of the Jfet and the 47K from Gate to ground.
Old 19th February 2003, 09:00 PM   #5
what negativ aspects are there by doing this?
Less gain?
lower damping factor?
no more linear frequence up to 100 KHz?
Does it sound warmer und more clearly?
regards
Günter
Old 19th February 2003, 10:44 PM   #6
The one and only
Less gain?
More gain
What damping factor? It's a current source.
Probably not to 20KHz, but so what.
Maybe warmer at low levels, certainly not more clear at any decent wattage.
Without feedback, I see this as a low power (5 watts or so) mid/top amplifier for horns. For this case, better off to ditch the JFET input and drive the Gate through 221 ohms and bias it with an 8 ohm resistor. If you want a schematic, say pretty please and I'll draw you one.
Old 19th February 2003, 10:56 PM   #7
till is offline till
Banned
please
Old 20th February 2003, 06:00 AM   #8
please, Mr. Pass
Old 20th February 2003, 03:38 PM   #9
The one and only
OK, I'll post it Sunday night.
pass/ - likes his glass of wine on sunday nights.
ZEN V4 without feedback loopHide this!Advertise here!
feedback loop rmenger Instruments and Amps 4 21st October 2006 07:04 PM
Electrolytic in the feedback loop yup Tubes / Valves 30 9th September 2006 07:56 PM
feedback loop rmenger Parts 0 29th July 2004 01:24 PM
Zen V4 Feedback Loop Extension dcmohs Pass Labs 1 14th March 2003 05:35 PM
Feedback Loop help KevinLee Solid State 4 1st December 2002 01:39 AM
