Old 13th December 2007, 08:03 AM   #1
Bakmeel is offline Bakmeel  Netherlands
Bakmeel's Avatar
Default Grounding the Aleph 2
Hi all,
The Aleph 2 incorporates a 5 ohm NTC thermistor to connect chassis and circuit to ground.
Grounding chassis via a thermistor is in fact not allowed by European regulations, and I also prefer not to. I can easily isolate connector shieldings from the chassis, so for ground loops it should not be a problem.
It gives me the choice of grounding the circuit perhaps by an other means. I can leave the NTC, or maybe put a more fancy solution with a little switch or relay, or perhaps paralleling such a relay with a high ohmic resistor just to keep circuit ground properly referenced to ground, without allowing ground loops.
Does anybody have a suggestion?
Thanks,
Bakmeel
More Power Igor! More Power!
Old 13th December 2007, 04:02 PM   #2
MEGA-amp's Avatar
You can also connect your circuit ground through the ac side of a bridge rectifier as shown below which would eliminate any possibility of ground loops.
(as taken from ZV4)
Old 14th December 2007, 11:56 AM   #3
Bakmeel's Avatar
That seems like an interesting alternative, yes...
What is your opinion about manually switching ground?
Old 14th December 2007, 02:53 PM   #4
I don't remember the Aleph 2 using a thermistor to ground--I thought it used a resistor. In any event, a fixed low value resistor, say 3 to 5 Ohms, would be one alternative.
Manually switching ground can give you options when dealing with ground loops. Guitar amps routinely have exactly that sort of thing.
Grey
Lions and Tigers and Grounding Problems, Oh My! DoZ Grounding... EchoWars Solid State 37 3rd August 2008 08:50 AM
Extraneous Grounding Question for Aleph's P. Lambda Pass Labs 1 30th July 2007 12:32 AM
LM3875 kit grounding, optimal grounding for separate amps and psu? findog Chip Amps 9 16th May 2005 09:27 PM
PCBs for Aleph 2, Aleph 3, Aleph 4 and Aleph 5 amplifiers kristijan-k Swap Meet 64 12th September 2002 07:55 AM
Page generated in 0.07600 seconds (71.74% PHP - 28.26% MySQL) with 11 queries
