Power Calculations - Page 2 - diyAudio
Old 15th November 2001, 12:13 AM   #11
tortello's Avatar
There was a good review about this amp in a Italian magazine, AUDIOREVIEW (n179, March1998).
They measured about 85Wrms into 8 ohms and about 69Wrms into 4 ohms.
The automatic setup stops the measurement when the THD begins shooting up.
Old 15th November 2001, 12:32 AM   #12
Warp Engineer
On Holiday
AudioFreak's Avatar
yes jduncan that is correct.... a true single ended design can not deliver more power into a lower impedance.... however you can design a single ended amp that changes to push-pull when it "hits the wall".
Old 15th November 2001, 02:12 AM   #13
jduncan is offline jduncan  United States
Send a message via AIM to jduncan
ok, so given this agreement, can somebody please recap how the output power is calculated?
Old 15th November 2001, 02:50 AM   #14
Whoa, put on the brakes!
Some of the Alephs can increase into lower impedance loads, and some can't. Why? Because of the bias current. Note that the baby, the Aleph 3, develops 30W into 8 ohms, then doubles into 4. It also has the highest proportionate bias current. That's not a coincidence. All amplifiers will current limit at some arbitrary load impedance (note that the Aleph 3 delivers the same power at 2 ohms that it does at 4...). You can increase the current on the Alephs provided you can take the heat and the output devices don't fry. If you want to keep doubling the power down to 1 ohm, increase the bias current--but be prepared to deal with the heat and power supply issues. I run my Aleph 2s about 10% hotter than stock. I've got current to burn (1kVA transformers) and a water-cooled system to get rid of the heat. I've been thinking about fiddling the bias upwards, but haven't gotten around to it yet. It's not that important to me as far as power goes--my midrange drivers are 5.3 ohm, purely resistive--but for sonic reasons.
Grey
Old 15th November 2001, 09:23 AM   #15
tortello's Avatar
Yes AudioFreak, you're right.
This is the "trick" to obtain from some of the Aleph designs much more power on heavy loads with relatively "low" bias current.
You can choose the threshold [Threshold in Pass Labs?! :-)] form single-ended to "quasi" push-pull by the variation of R29, for the Aleph 4.
This resistor trims the dynamical balance between the current source (upper stack) and the active side (lower stack of Hexfet): when the two currents are equal, whe have always a true single ended operation, but the load impedances behavior is only due to the bias current.
The Pass patent doubles the driving capabilities.
Suppose that we have an Aleph 4 running at 2.75A:
-with 619 ohms for R29 whe have a perfect simmetry between the current of the two halves, or the current source output is about 50% of the load current.
In this case whe obtain about 60Wrms into 4 ohms, the operation status is always single ended.
-with 513 ohms for R29, the upper side current is about 43% greater than the active (=lower) side current, at a certain point the operation becomes a sort of push-pull (at about 40Wrms) but now our amplifier can deliver about 85Wrms before clipping, always into 4 ohms.
We have the best results, I think, with the complete simmetry of the two halve's current, or the currents source output about 50% of the load current, but in this case you must increase bias current for a convenient low-impedances behaviour.
[Edited by tortello on 11-15-2001 at 07:33 AM]
Old 15th November 2001, 12:22 PM   #16
wuffwaff's Avatar
Hello all,
Im a bit puzzled now. How can I calculate the maximum output current of this design?
I simply looked at the primary fuse (Aleph5: 2A gives about 2 x 25V/4.5A per channels wich fits)too estimate the max. current available. In case of the Aleph5 this worked quite well......(wrong method, right outcome)
so how is it done?
william
Darling power supply calculations hembrook Tubes / Valves 14 27th August 2008 04:12 PM
Calculations for new Power transformer kskr Tubes / Valves 3 3rd May 2006 09:29 AM
Copyright 1999-2017 diyAudio
