Hi
I recently bought a bag of 50 J310 Jfets on Ebay without any direct plans for their usage.
Some of them will probably end up in various linestage prototypes, but I have this other idea that I´m been contemplating for a while: a cascoded Jfet "power" amp with output transformers.
Jfets usually goes belly-up when the drain-source voltage exceeds 30V or so, but if we make a cascode with a high voltage mosfet on top of the jfet(s) they should be safe to use at (much) higher voltages.
Next issue is the low drain currents allowed by the jfets.
J310 seems to be able to swing about +-10mA which wouldn´t even tickle an 8 ohm loudspeaker.
Ok, I could buy a couple of hundred J310s and wire them all in // but I´m not sure it would be worth the effort.
The tubes guys have faced the same problem since the dawn of time (or at least for about 100 years), we have all the voltage swing we need but almost no current.
A transformer between the output device(s) and the load is the obvious solution.
I am well aware that output transformers are considered the worst bottlenecks in most tube designs and I completely agree with that but hey, I´m in the mood for some experimenting here...
Let´s say we take ...5x J310 and wire them up in // with adequate source resistors and gate stoppers in a common
source configuration.
Let´s set the total drain current to 55mA by chosing the right source resistors and then we put something like an IRF840 on top of the whole thing to deal with the high voltage and to dissipate most of the power. 10V across the jfets would probably be just about right.
Assuming that each jfet can swing from 2mA to 22mA (according to the datasheet) we can get a total current swing of 100mA p-p.
With a transformer forming a 2,5k load on the drain this current swing will render a voltage swing of 250V p-p giving an output power of... just above 3W!!!
About the same output power as the legendary 2A3 triode, but at much higher efficiency and without all the troubles related to the direct heated filament...
I guess the supply voltage would end up somewhere in the 150V region, easily available from an isolation transformer...
And, uh, one more thing: The complete absence of (voltage) feedback would leave us with a very low damping factor...
well ........ be my guest ;
I have da toobz for that .
even my preamp is more powerful ..........
http://www.diyaudio.com/forums/showthread.php?postid=1364291#post1364291
Oh, I should have put a " " after those " "s...
As I said, I´m just in the mood for some experiments. If this thing would work as expected (or anywhere near it) it would still not be a very versatile amp.
Perhaps it would sound good driving high eff fullrange drivers in open baffles but regular speakers with crossovers and tuned boxes would probably get very confused...
It's all built up and waiting for me to finsih it one of these days.
Let me know how it turns out!
step-up trannies up front
I like your output stage idea, but for gain I think I would prefer triodes rather than step-up transformers. Especially as my linestage already has step-down output transformers...
Fuling said:I like your output stage idea, but for gain I think I would prefer triodes rather than step-up transformers.
Perhaps. Though I think you should give them a try sometime. As long as you avoid overloading them at the lowest frequencies, I think a good quality step-up transformer offers the cleanest and sweetest voltage gain I've ever heard.
Well that's because the active devices in your linestage are being used as voltage gain devices. For the amplifier I'm suggesting flipping that around and using transformers for signal gain and the active devices for impedance transformation in the form of voltage followers.
se
Fuling said:Didn´t Susan Parker use ordinary mains toroids as stepups in some version of her Zeus amp?
Yes.
If it is managable to get full frequency response through such transformers it would be fun to try a pair with adequate input and output buffers.
Depending how much you're looking to step up, you may not need an input buffer.
How much gain are you actually needing for the power amplifier?
se
Virtually none actually.
My linestage has a 3x gain so the easiest thing would be to just add a simple Mosfet follower to drive the speakers.
I prefer not to have lot of excess gain in the system.
However, mosfet followers are not the topic of this thread, cascoded Jfets gainstages are.
I realize perfectly well that a circuit such as described in the first post is not very useful and even if it would work as intended it wouldn´t be of general interest form most DIY:ers.
If I ever build a prototype it will have an extremly high "just for fun"-factor.
I might however have some use for the basic circuit in another amp project. I have a bunch of old triodes that requires positive grid voltage and thus grid current to operate in class A.
I have this idea about using jfets and mosfets in the gain and driver stages.
A jfet/mosfet cascode combo as voltage amplifying input stage driving a mosfet follower that feeds the tubes.
Done right this could be superior to any tube based driver stage.
The power tubes requires about 80V p-p swing and 100mA at positive peaks (30mA grid current at idle).
Might I suggest a preamp instead?
Instead of the step-up transformers?
- Jfet/Mosfet cascode with OPT
