Hi there, I. am building an aleph30 to fullfill my needs for a total active system.
Now I got on the output on both channels 22,3Vdc, the mosfets on the + side are getting warm, the - side staying cold. The voltages on the channels on R37,38,39,35 and 36 are all between 22,4V and 22,8V only R34 gets 14,5V. Measuring 9610 gets between D-S gets 32,4V, 0,03V and 8,34V. Between G-D gets 28,4V, 14,2V and 13,8V. Between G-S is 3,9V, 14,2V and 5,4V. Anybody here can tell me whats going wrong? Thanks Teake |
#2 | |
give us exact schematic , by which you made your amp ; there are numerous schematics - designation wise . gain transistors (- side ) are not opened enough ; you must have more current through drain resistor on first input mosfet
my Papa is smarter than your Nelson ! tnx to thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
#3 |
Hi Choky!
The boards are from Brian GT and I don't know the shematics I think its from Mark Gulbrandson, I will search for it, Teake |
#4 |
I got on Q4 CE 8,8V and Q5 4,2V and on R11 9,1V, Teake
#5 | |
compare this with your pcb . then - using designation from this schematic , write what you measure
#6 | |
edit : if values are as on this schematic - you have systematic problem ,same on both channels recheck orientation of parts etc did you mounted input mosfets on some shared heatsink ?
#7 | |
For starters, the zener at the top, Z5, and the orientation of the irf9610 Q3.
Looks like Sponge Bob has killed another thread. |
#8 |
Hmm Jacco, could it be the bypass of the 2,2Uf filmcap on Z5? Teake
#9 | |
nope
#10 |
Here is the schematics I refer to
| BJT for Aleph30 | same | Pass Labs | 1 | 5th May 2007 03:48 PM |
| Help Aleph30 | Kooka | Pass Labs | 9 | 18th February 2007 02:03 PM |
| Aleph30 very very hot | arold19 | Pass Labs | 7 | 12th February 2005 01:55 PM |
| 1 Ohm For Aleph30 | gema | Pass Labs | 2 | 30th May 2002 07:40 PM |
| Aleph30 | Mano | Pass Labs | 3 | 7th January 2002 06:01 PM |
| Page generated in 0.10678 seconds (77.94% PHP - 22.06% MySQL) with 11 queries |
